hurro,
my bother was saying something about how the cameras on the ring rd don't snap you for going over the speed limit but they calculate something between between 2 or so cameras that you drive past then they work out whether you were speeding? :) :)
does anyone know what i'm talking about or where i can get some info on this?
is this old news? lol
thanks
  • Replies 42
The way I herd that it works, is that both cameras record your vehicle. Software matches the vehicles up (REGO) and calculates the time it took to for you to travel from A to B and works out your speed. There will also be the normal Fixed speed cameras and road patrols.
I think it's only the ones on the Hume HWY bypass that snap you over distance.
I'd imagine it would be too hard to do the same on the Ring Road, with the variable speed limit.
Off topic. But do you work on prospect st in box hill. I thought I saw your car there today.
R-SPEC: Yeah, my missus lives just off Lygon St, so it may have been a possibility it was my car.
Ray: The cameras that detect your speed point-to-point are on the Hume HWY.
The Ring Road cameras are:
Greensborough Bound:
Boundary Road - Behind the Signs
Western HWY - Behind the Signs and on the Exit aswell
Keilor Park Dve - Behind the overpass
Pascoe Vale Rd - Just before you get into the tunnel
Altona Bound:
Widford Rd Bridge - Behind the overpass
Calder Park Overpass - Hidden up high between the two bridges
Western HWY - Just before the exit, hidden behind signs
^^ No, having to have to do 20Ks or less on a freeway just coz you felt like speeding for a sec beforehand
thought so.
Edited by R-SPEC
I played a part in the setting up of these the new western ring road speed cameras. I told my boss when he gave me the job if I had a religion this would be against it. They are the old fasion if you speed you get your photo taken type. There is even a second camera linked to the system that takes a pic of the variable speed sign at the same time it snaps the speeding vehicle.
The Westy ring road has these cameras, saw them yesterday, also the temp signs saying 'Cameras are on, speed cameras reduce accidents' or something like that. Mind you i nearly side swiped a falcon wagon full of newborn babies reading it!
I had a thought ....... and Yes it hurt...... If you abide by the speed limit...... mabe ..just mabe.. you won't have to worry about getting booked?
That said .... i spend so much time looking at my speedo these days, that i rarely have a chance to see where i am driving.. so look out for all these responsible drivers doing the speed limit while running you into a concrete pylon.
are u serious that there are speed cameras that measure the time it took between the two and book you on that!! Where exactly for a fact are these cameras.
There is nothing new about this style of camera, these have been operating on the M1 in the UK for several years around the midlands area. They run over 3 sets and the idea has most likely been deployed in other areas by now as I remember when they were trialled. :)
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
