MAR55S, I thought your stuff was mailed a while ago, I'll check it out again for you.
BOO57A, again, I'll check out where it is up to for you. Guys you might also like to try the new feature that SAU has installed for this one too (we are trying to work his bum off atm) and give Ewen (Aurora) a quick email. He is our Memberships Co-ordinator now and has been doing a sterling job. His email is [email protected] OR [email protected] Thanks Guys.
Sorry, what I meant was that the forms that I collected got to Shell, the info packs and stickers went out and the membership process worked.....
I didn't mean to say that I was the only reason that Scott and Sam joined. Of course I wasn't
My bad - I shouldn't have said 'recruitment'
Still have not got any conformation of membership but the cheque has been presented and cashed.
hey Scott, got your form today from Prank...just gotta make u up a card and I should be sending it out next week :cheers:
  • 4 weeks later...
hey guys
i just noticed my name on the list is down as 2GU UPZ can some one change it to 2GU UP 2
oh and btw how long does it take for the membership card to come?
i signed up at the UAS sale and havnt got it yet
thanks
anf
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
