std ecu??? use fuel cut defender?? wat power....u got dyno sheet to show...please list mods and costs........i am very interested
cheers,
daniel
Yes, Std Ecu remapped to suit : RB25 Turbo,exhaust, fmic etc. Factory fuel/boost cut raised, 180 kmh speed cut raised, fuel and timimg adjusted and all checked with AFR meter. Not been on Dyno yet but there is a noticable gain in power and driveability. As for costs, you would be better off talking with Toshi, but I paid $230 for 2-3 hrs work. Well worth it in my opinion.
Just had my R32 Gtst computer remapped by Toshi from this forum and I am quite impressed with the results and would recommend him anyday for a remap in Sydney. Best valued performance gain yet.
do you know if he does r33 gtst ecu remaps? got contact details for him? where is he based?
Remap is the best $400 I ever spent. Was done on a dyno.
With the standard ECU as soon as you add a big exhaust and up the boost they run ridiculously rich ~10:1 afr. With the remap I had it leaned out to 12:1 throughout the rev range/load points. In turn I get MUCH better economy, power is up from 127 to 151rwkw. More top end, smoother idle. Its just so much better. Had the speed limit removed as well.
Highly recommended, just as good as a stand alone ECU as they can do timing and fuel. You still retain your standard knock features, excess air flow cut (if say your waste gate hose splits).
I got mine done via the speed lab, he should be here on these forums do a search. R33 computers are very hard to remap so not many people do them, if any at all.
Do a search in the Members section for "Toshi" and he will come up. Not sure about the R33 remap, send him a PM and ask.
Tim
Just found his Mobile number, give him a call about the R33 remap etc , Toshi 0410490049, he is at Nth Ryde in Sydney.
Tim
  • 3 weeks later...
R32 remap chip $250(Sydney only).  check A/F and modified ecu(fit socket to ecu) check diagnosis
Remap make real time on the road by emulator. If you want to check on dyno I will come with you.
R33 remap chip for boost up will be $310 (Sydney only)  check A/F and modified ecu(fit socket to ecu)
Check diagnosis , remap make not real time .I will calculation from your cars A/F.
This is R33 auto dyno sheet. s
(red) Std boost (7.4psi) std ECU.152kw
(green) Std boost (7.4psi) my chip. about 170kw
(blue) boost 11psi my chip. 185kw
http://users.tpg.com.au/yuna/dyno%20kw1.jpg
[basic data changes in the chip]
Fuel map
Ignition timing map
TTP max
Remove speed and boost limiter
You be able to request rev limit.
E-MAIL [email protected]
Ph 0410490049
*) About does not work remap performance rom(chip)(lower power than std ecu)
Early, later model has the same fuel and ignition map however, program is different depending on the ecu number (ecu hard ware is different).
I have checked some cheap roms(chip) and programs differ depending on the ECU number as I have mentioned previously.
Some had later model program rom(chip) fitted to early model ecu(eg;mec-212 program rom(chip) fitted to mec-106 ecu.) and some with R32 rom(chip) fitted to cefiro ecu(never start engine).
So, when you buy rom(chip) I would advise you to check ecu number.(MEC-000)
It is best not to buy from places where they are unable to remap chip according to the ecu number.
Same goes for when purchasing secondhand roms(chip). Always check the ecu number.
Also check A/F before ordering the rom(chip). Many R32 appear to have airflow metro or fuel pump problems(If airflow meter is dirty A/F will lean). If remap rom(chip) is fitted when the car A/F is lean, your engine will blow up.
Many people seem to hold questions about remap rom (chip) and a lot of not good condition skylines exist.
So I will start free check now.
When boosted up and fitted a properly tuned rom, your car will most certainly have gained power. (If slower or back fire etc it is most likely due to some trouble on your car)
1)Free program check
If you got remap ecu or remap rom(chip) and feel that there is not much difference or lower power than std ecu,very rich etc, I will free check fuel, ignition map and program.
2)Remap ROM(chip) free trial (Sydney only)
If you are interested in remap ecu and road testing for the difference, you’ll be able to road test anytime.
3)Free check diagnosis(Sydney only)
If your cars engine etc has problem (eg: back fire) I will check diagnosis.
TOSHI(Im motor mechanic)
Ph 0410490049
[email protected]
Toshi do you also offer real time tuning on a dyno so that the map is optimised for a specific car ? Obviously at a different price.
Please tell me what type of engine.
If that has nissan consult port I be able to tune.
Because I need map trace.
toshi, if you have a wideband AFR meter are you interested in doing a little tuning on my GTR? It's running a power FC, but I just want have the lower part of the map looked at for better economy. it's not running in closed loop properly due to fauly 02 sensors, so I want to turn off 02 feedback and just tune the 'cruise' area of the map manually.
Yes,I have wideband A/F meter.
I be able to tuning.
Why you do not change 02 sencer?
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
