  • Replies 144
Do we have to sign up or something or can we just rock up on the day?? Also lets say if I came at 11am is it too late... or will they still allow me to race as it says it closes at 4pm. Just wanted to see whether its like sunday where even if you rock up at 2pm you can race till 4pm....
The Datsun has developed a problem with the fuel system that I'm still trying to sort out and find, but I'm having no luck and its a pain in the ass by not being able to drive it anywhere to be looked at.
So I will take the cover off the GT-R and bring that up for a run, its just been freshly serviced and dynoed with a larger fuel pump fitted to it and is ready to go!
Should be in...wether i find a helmet or not
And wont be the fastest time 2nd gear snycro isnt the best in my gearbox :worship:
like me, 4th gear synco crunches every time :(
i still should be there at this stage...
I will be coming from melbourne, a good 2 hour drive I reckon lol
Most of us will be meeting up in Melbourne and going up together
So come join us..
See ya there... :D
DRAG DAY CONVOY leaving Melbourne
spewing, i'm out :O
clutch started slipping yesterday + 4th gear synco major crunching = no point going to drags.
time to rebuild box and new clutch at same time.
i was so looking forward to this..... :)
i need a lift or someone to drive my car
Paul, how long does it take to get to the meetpoint from your house? I could probably come pick you up
Unless you could somehow get to my house in the morning...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
