  • Replies 237
Posted Images
scotsman any chance i could get you to do driver training with me please?
Screw chris, he's a hack probably put you into a wall or something. Could be worse though you could get ryan and in that case you'll end up having to get jack to tow you home because he will have blown up your engine! :laughing-smiley-014:
no way Sandown is scarier than PI!
am I a traitor for wanting to do the Maserati day there the week after instead? heaps less cars than the WRX days usually... I had 10+ laps in every session last time I went... bit pricier than the WRX days tho... hmmm
nick if you go that day I will go with you...I cant go on Wed cos I have to take ppl to the football.
My driver trainer is V8 Supercars 2 on Xbox, did a 59 second lap around Sandown hahaha, wooooooooooooooooo
Been looking through youtube for some incar videos, but most of the cars on there are slow, 1.35-1.40's.....
Wheres some Jack Footage around Sandown when you need it.
Edit: Found this Porsche Cayman S one on google videos, not to bad... still not super fast
http://video.google.com.au/videoplay?docid...7&q=sandown
Haha - my very first track day way back when I'd been playing V8 Supercars 2 on my PS2 to learn the track and as I hit turn 1 for the 1st time at full speed I was unsure where to brake. But I knew in the game I was braking at the 100m mark and I figured the cars in the game were going faster than me so I guessed 100m was going to be a safe spot for me to start out at.
:cheers:
Luckily for me I didn't also try and test out whether the kink was flat out like it is in the game afterwards.
hahahahah just clocked a 58 second lap.... its crap tho, i'm doing nearly 300k/h before turn 1 from a standing start on the grid!! hahah my arse.
Yeah trying to get my head around the kink at the back about how fast to be taking that, more important to set yourself up for the left hander after it i think....
LOL...Sega Boy! :)
Big thanks to Tom, car has fresh sump of oil, flushed brakes and a tank of V-Power Racing. I also backed off the rear swaybar from the hardest setting to the middle. Roll on Wednesday.
Im going to watch the video footage of my last trip to Sandown. Suss out where is was driving like a girl last time round :(
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
