Due to unforeseen circumstances, Sarah Biggin has stepped down from the position of SAU-Vic Secretary.
As such, the committee are going to hold an emergency election at the next general meeting scheduled for Tues 17 April.
If you would like to stand for this position, you must have fulfilled the following criteria:
* Be an active member of SAU-Vic
* Must be at least 21 years old as of April 17 2007
We already have 3 runners for the position of Secretary. They are:
Caryn Lacey (Kaz180)
Melinda Blizzard (Min aka Scotsman's better half)
Alan Calleja (Al)
If you wish to stand for the role of Secretary, you will need to be nominated and seconded by 2 active members of SAU-Vic. You will then need to accept the nomination by 12pm Mon 16 April at the latest.
We will be holding a vote for the role of Secretary at the general meeting for all ordinary and life members.
Should you have any questions in regards to this process, please email the committee at [email protected]
Good luck people.
https://www.sau.com.au/forums/topic/164075-position-vacant~-secretary/
  • Replies 57
As its an Exec position.
Without checking the constitution (cant till friday as i dont have a copy here)...
I would be of the belief it requires an EGM (extraordinary gen meeting) to decide, as it requires a vote.
That is the fair thing to do, being the rules are to be followed.
It isnt about handing stuff out to people just "because"
Guest
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
