S/A Car Seat covers, Group Buy.
Guest MFX_R33
I have seen some interest in the Snap-On Style car seat covers. If there is an interest i can make them for the forum members with the Skylines Australia logo on them, for a very cheap group buy rate.
I do make them for alot of prominent companies around Sydney, and they are a quality product.
I can make them in Black, Blue, Purple, Red, Orange, Yellow, Pale Grey, and White.
If there is an interest of 10 or more, I can do them for a forum rate of $50 a pair.
Jeff.
Before I am shut down by moderators I am just offering this for a group benefit, if I am over stepping bounds, I appologise.
https://www.sau.com.au/forums/topic/16433-sa-car-seat-covers-group-buy/
  • Replies 119
Guest MFX_R33
I don't have back one's yet, althoughI have been getting more call for them. The trouble is that it is harder to make 'one size fits all' rear seat covers, as some have headrests, some don't, some are big some are small.
So I am looking into it, but at the moment I don't do the rears.
Jeff.
I wouldnt mind some seat covers.
Would it be cheaper if a number of them are dumped at one of the customers house, then other customers living near by pick them up from there?
I'm thinking of this if a few northern beaches people order them.
Mark
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
