radius rods? is that a term im not familiar with or what, all of the sus on a 31 front end consists of tie rod ends, castor rods, swaybars, hubs / control arms and brakes....
But afaik no.
by radius rod he means castor rod, and no, you dont need to run the r32 one, just use the R31 rod.
cleaned out cooling system tonight, was filthy.......also hooked up water temp gauge.
Rears are on metal and need to get the rotors machined, so if anyone knows a cheap place to do so let me know, also need some bluey calipers as they wont seize with the hydro handbrake, unlike pos r31 items.
Cool car, gotta love RB20 power! Where and how much did ya pick the engine up for?
What is the best cheap coilovers out there? Trent obviously doesn't like the D2 coilovers and I've heard bad things about HSD, what about ISC?
Who are you? Scott from CSA? I'm a little bit confused.
Cars almost complete, got my vs calipers to go on rear with pads yesterday, minispool is on its way, and hydro lines / master will be purchased this weekend. (will be making our own bracket / modifying the original handbrake)
Still waiting on whiteline swaybars to arrive, fitted boost controller (turbotech) last night and goes real well......open wheeler sucks but.
I'll be out for drift school, who else from here's going out?
Little update:
Got an Xforce R33 front / dump pipe, and car will be going in to have its 3" exhaust into twin straight pipes done at aussie discount exhaust soon.
Fitting minispool this week, as well as hydro and vs rear calipers, so shes almost ready!
  • 4 months later...
-Updates- :D
Tried the 17x8 and 17x9 drifteks off my gts-x on it with 30 and 35mm bolt on's - yum.
So being equipped with an rb20det, bit more boost, fmic, exhaust, coilovers, swaybars, minispooled diff, hydro etc - she saw the track for drift school for the first time.
few vids -
http://s103.photobucket.com/albums/m137/dr...driftprac13.flv
http://s103.photobucket.com/albums/m137/dr...iftprac13-1.flv
Then she hit track again at AIR
vids-
http://s103.photobucket.com/albums/m137/dr...n0508.07014.flv
http://s103.photobucket.com/albums/m137/dr...ft_prac__ev.flv
Daytime prac -
2 vids -
http://s103.photobucket.com/albums/m137/dr...nt=P1060113.flv
http://s103.photobucket.com/albums/m137/dr...rent=Evsr31.flv
As she is now full mods consist of -
1988 R31 Skyline Exec, colour coded white, New front right / left guards, stripped interior with full CCS Bodykit and mfx front lip - converted from auto to manual rb20det silver top from an r32 - extreme hd clutch and blitz access ecu
Auto Gauge - oil temp, water temp, boost gauges
Just Jap fixed back race seat with 4 point TRS Harness
Hydraulic handbrake with rear vs calipers and slotted rotors
Minispooled 28 spline 3.8:9 ratio diff
Whiteline swaybars front / rear with new noltec bushes
3rd's productions adjustable castor rods
D2 a31 coilovers all round with s13 hubs, control arms, calipers / rotors
Full service on the engine
New battery, clamp, sandwich plate adapter for oil temp / water temp
Work stich rims 17x7.75 and 17x8.75
r33 xforce 3" dump / front with custom 3" under diff zaust
35mm and 30mm bolt on spacers
Bosch 040 fuel pump installed
Oil catch can setup
Turbotech controller on 14.7psi
Whiteline strut brace
New Avs rims 17x8 +24
17" pair of hack drift rims
Car was dyno'd recently and made 176.6rwkw on around 1bar, was impressed as it hasn't been remapped yet. This was on the Boostworx dyno.
And as she looks now -
Future mods -
Remap, 25 turbo, respray. yada yada yada.
If you actually bothered to look at all of the write up, lots n lots of work has gone into it and countless hours, but damn its worth it.
Cheers,
Ev. :P
to date - cost me $8,950.00
Edited by evsr31
man it looks tough as now, If you respray it go for something totally different for a 31... bright f**king yellow :( would look hot with the white wheels + stand out and get you noticed a bit more.
Edited by Simon-R32
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
