  • Replies 62
hrmmm. talk of height of the cooler??????? whatt tha. lol
anywhere on the lower half of the radiator leval so the air gos through it not over or around it. that hks kit looks realy nice. with the ducting.
for the track a minimum of 25 rows will be ok. ive got two. still gets hot but. one in the brake duct one infron of the radiator making it over heat :)
noone - i reckon where I've got mine is your best bet. That way a bit of bent aluminium shrouding can duct directly to the front bar inlet. Also there is no other cooling or obstructions around there.
h2k - that's not so good as you've already passed air through the intercooler (slowing airflow, and heating the air), then partially through the oil cooler (remember air velocity is now reduced) and then through the radiator (if it goes through it at all).
remember what i said earlier that if you don't have exit vents, or enough airspace behind the cooler (be it intercooler, oil, or radiator) it will do NOTHING to cool the face of the cooler. Think of the practical example - if you open up the window of your room, and shut all other doors, there is fark all air flow as it doesn't have anywhere to exit. If you open the door the air will travel in the window and out the door, i.e. the path of least resistance. You MUST allow the air to escape once it has passed through the core.
hope that helps
totally agree Ronin, Baron an all an after a bit a dickin around this arvo looks like I can just squeeze it in there
still a little concerned about the angle but like ya say bit a ducting allgood
Looks like the braided lines supplied wont be too helpful might be able to shorten on an use the others they might be a little short though
Still gotta finalize the position for the filter relocater
hopefully mount it down low in front of the crossmember see how it goes
and holesaw a bunch a holes into the plastic guard liner too ventilation ventilation
Just wish that intercooler piping left a little more room
I had the oilcooler mounted in front of the radiator, but this setup is much better. It's a HKS S-type, deflectors etc. are included.
well considering i'm halfway through my fuel system may as well start looking at the next thing I wanna do which is an oil cooler and relocator kit.
Looking at the nengun site the HKS Type S kits seem to be the basic ones and the Type R kits are the ones that come with the oil filter relocators and ducting but according to the HKS website only the Type S kits are avaliable for a 33GTR.......actually no there are type S kits that come with ducting as well :laugh: omg so hard to understand. Can anyone clear this up? does the Type S kit for a 33GTR come with the ducting but not the filter relocator?
Hmm can probably live with the filter still being down underneath, keeps it out of harms way I suppose and it's not that hard to change anyway, K&N hex head filters FTW!
crappest pic ever but my remote filter is on the front of the cross member... awesome for access to change the oil... probably not so good for something ripping it off.
but if something rips it off, say goodbye to the front bar, lower lip, intercooler too!
After looking at the ripple strip paint on my crossmember I think thats a little low and exposed for my liking
that said I doubt it woulda hit but still a little scary (mine is too low though too)
appreciate all the pics though guy
Was thinking the other side probly only a foot or so forward of the normal mounting point
but much much easier to get to an will try an tuck it up a little more
not too sure how to route the lines and thinking that my choice of mounting spots may be why the lines look like they are all wrong
probly wouldnt have brought a kit if I were doing it again individual parts
and custom lines to suit!!!!!
Edited by noone
Others have touched on it...but air is lazy and will take the path of least resistance. Which in 99% of cases is around the cooler unless you force it to go through, ie ducts and guides. There is also another place to convenient install them which noone is thinking about :) Mush better performance, though is a full weekends work doing it :(
horizontal mount with 90 degree (high pressure) ducting from the front bar, with neg. pressure of air under car drawing air out of cooler?
or out back near the diff?
lol...we have had this discussion, but thats one way., Buit for road cars with stones. water splashing everywhere etc. You only have to spend 2 hours lookign at race cars to see a whole other possible ways of doing it that may better suit your sized cooler and where you want to put it
Sorry ronin meant my cars too low not the oil filter
Yeah I figured that was the tow hook thingo in front of where yours was mounted so
realisticly its probly fairly safe I guess
Mine is actually still in process of being decided upon/mounted
but back to work tomorrow so I guess it wont get finished now for a week or so.
Damn braided lines are going to be all wrong methinks Damn!
Roy are you talking about me or noone inparticular???
Any suggestions much appreciated bud
Looks like the GTR's getting group buy suspension too so might be off the road for a little while
had a quick look tonight and that spot actually is looking better an better Ronin assume u used the bolt holes for the power steering lines,
Had wanted to tuck mine up near the drivers side engine mount but I dunno if I am going to manage to fit it in their though its tight!!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
