I bought a Ku Engineering plenum, I was surprised how little effort it too to fit up, it cleared the clutch master and only had to make a small modification to the water lines under the plenum.
Great price also, got the plenum and a Sard rb26 fuel rail including mounting brackets for a little over $800 Fedex'd
Edited by murrayis
hey
its coming along great.
i wanted to order the tomei rb24 pistons but they are discontinued. do you think i could get ross pistons to make me up the same pistons as yourself. i have gtr crank and rods and 9.25mm lift 270 in&ex tomei cams with solid lifters
let me know,
cheers
hey
let me know,
cheers
Yea that shouldn't be a problem. All the info I have on them is on the previous page so that should be enough info for you to call them and tell them what you want :P
Just remember AUS vs USD atm isnt that great might be worth trying ACL etc. see if they can make a custom set up for you.
Is the Ku Engineering plenum any good?
I was looking at one myself but its hard as i dont want to buy something and find out it sucks after a paid for it lol.
Seems to be fairly good, only comment I had for the plenum was the intake runners at the face of the plenum are a tad small but nothing and hour or two on a dremel didn't fix for mine :D
Inside was nice and smooth no visible defects, just a bit of cleaning on the outside to remove the metal polish. Fitted past the clutch master thought much of a drama, I spoke to Jack alot from Ku Engineering he was very helpful with dimentions etc so I knew it was going to fit.
On another Note,
A few changes have to be made before I goto the Dyno to get it tuned.
1) I need to lower the gearbox as I think its jutting the gearbox tunning somewhere when the engines running
2) Exhaust need to be lowered 20 mm at the front and a side effect of lowering the gearbox 10mm will bring it in striking distance of the tailshaft.
Alos how do you seal a vband dump pipe? Mine leaks in the gap on the Clamp?
Nah I have a BMI 80mm I was going to get one but got offered this one to pay a bill ;)
Just an Idea of shipping he posted it on Saturday, it arrived the following tuesday he told me on msn on Wednesday hes posted it lol
Edited by murrayis
Well its all done! ready for the tune!
But... Was running it a little yesterday messing with the idle bringing it down from 2000rpm to sit around 1200rpm when.... I noticed a nice water feature from the engine bay shut it down quick smart to investigate and found the wate line under the intake had 4 or 5 pin size holes in it all spewing out coolant. Quick tip always replace all those old hoses even if it look fine its the only hose I didnt replace in the water system.
Ordered from nissan $30 later it will be here monday :ermm:
good work mate. i love seeing a project from beginning to end.
I am looking forward to seeing how the tune goes and what sort of response and power you end up with.
you have done all the hard yrads and now comes the time to enjoy the results.
goodluck!
Well got the new water Hose today Another $30 for the local nissan part department.
Fitted it all up started it up, bleed the system topped up the coolant. But noticed a slight hissing sround from Number 1 injector shut it all down and took a closer look, Last time I had the injectors out I musn't of put the o-ring back in square so it was half jammed down the hole... pulling air down past the injector... not good!
Pulled all the injectors out and checked over all the o-rings, added a smidge of silicon lube to eash o-ring just to make the seal a tad better and reseated, fired it up problem gone :P
On a different note is there a 12v source hear the battery thats only active with the ignition so I can wire a relay to it?
Cheers
Cameron
  • 3 weeks later...
  • 1 month later...
Time for an update.
Today was the day that has been two years in the making... 7am picked up the car trailer got down to B.E.S.T performance who we had hired the dyno from strapped the car down all was running sweet.
After 45 minutes of getting the fueling correct we did a run and made 164kw on 6.3psi adjusted the fueling a little more 197.6kw on 6.3psi... and thats when the postive mood got shot down.
Third run something was wrong the entire run was 20kw short of the previous... lots of blow by coming from the cam cover breathers.... Ticking sound....
All I could think of was... Bearing...
Got the car home checked the plugs... no oil on them..started her up for a second ticking sounded like was in the head...
Tomorrow we will pull the head off i just hope its nothing major!
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to it's full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so damn hot in there, that made it all the more easy to remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. I was standing there looking at the car and said 'f**k it'. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
