ahh yeah.. gotta love those semester tests. The one I just got back from, they squeezed us into the lecture theatre like sardines, and the guy next to me kept on breathing REALLY loudly and I couldn't concentrate, all I could think about was screaming STFU!!.. also BOTH the people next to me had their elbows sticking onto my desk so I was COMPLETELY cramped. Crack the shits Rylan, CRACK THE SHITTTTSSS!!!
now apart from that completely random rant....
HAPPY BIRTHDAY PAT!!!! I can't believe your only 19!! You yougin you. Are you going out?
haha love the rant.
Would love to go out tonight but got 10% assignment due tomorrow :worship:
On another hand just received this from my old folks!
I know what ill be doing on the weekend! haha
