  • Replies 369
Posted Images
I have just signed up and thought I'd post some pics of my car.
Just got paint and interior done.
PICT0022-1.jpgPICT0032-1.jpgPICT0040-1.jpgPICT0041.jpgPICT0047.jpgPICT0050.jpgPICT0055-1.jpgPICT0067.jpgPICT0070-1.jpg
Great work dude! Amazing looking 33
Everything about it looks good - clean kit, awesome wheels, nice paint :(
Cant wait to check it out at the gor cruise - looks mint!
Mizzi: Sensational :)
Nicely kitted and not over the top, well done mate. :(
As i like to do some motorsport events, i prefer the factory plastic bumpers (for the occasions i hit a witches hat at 80+ km/h); but if i was to kit my car, it would be very similar to yours.
I live in Delahey, so hopefully i'll see you one day.
My car is currently (for the last 4 months and counting) getting an engine build/conversion so i'm off the road. But once it's finished i'll update my pics in this thread. Have a few cosmetic and engine bay changes in progress :D
Mizz's car looks even better in real life!
Will post up pic's of it in the day I took soon.
Very Nice Mizzi!!
AGREED! Lookin good bruv!! LOL n u were worried about how the colour was gonna turn out :(
Good choice on the rims!!! Whats next on the mod list?
How the hell do some of the P platers here afford it all ? lol dealers? :rofl:
Hmmm :rolleyes:
Only thing is an orange skyline isn't exactly the most inconspicuous vehicle for moving product. Best to have 2 cars.... Hypothetically :thumbsup:
lol
yes, i do mean femno's car, i just jerried then that i made a mistake..
anyone know what rims they are? I think i've seen a r32 gtr with similar work rims on their car, can't confirm tho
.....they told me it was just tobacco......
Yeah your right the rims are Works, model 'Maximer' 18 x 10s, they are quite a rare rim when you see a fair bit of gram lights etc, when i first saw them i loved them! and thus bought them! Alot of people (eg Roy haha) mistake these for veilside rims.
No, not a dealer just work hard for my car, havent got much else LOL!
Hot colour Mizzi! Looks expensive! Im not usually into the very loud stuff but i like that!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
