I have for sale the brakes off my R32 GTSt.
For sale are the following items:
Calipers
Front 4 piston (alloy) that are in great condition, were rebuilt and HPC coated, incuding pistons to reduce heat transfer into fluid.
Rear 2 piston calipers (alloy) that were rebuilt, though not as recently as the fronts. Were painted black but paint all but worn off. Paint was nowhere near as durable as HPC coating
Pads
Fronts - Ferodo DS2500s. Have done three track days (approx 25 laps total) and less then 2,000kms of street driving (new price $296.00)
Rears - Race Brakes Comp 2s. Have done 4 track days and approx 5,000kms. (New price $220.00)
Both sets of pads still have plenty of meat on them.
Rotors
Front - Near new 324x30mm DBA 4000 slotted rotors. Are normally replacement rotors off R33/34 GTRs. Have done 3 track days and less then 2,000kms of street driving (New price $450.00)
Rear - Near new 297x18mm RDA slotted rotors. Have done 3 track days and less then 2,000kms of street driving (New price $255.00)
Adaptors
Adaptors to allow you to run the 324mm front rotor with std R32 GTSt calipers. Machined from billet alloy. Have used these brackets extensivley on the track and there is no issue with regards to their durability. (Replacement cost for brackets is $800 less rotors, so around $350.00)
Asking $1100 ono for the pads, rotors, adaptors and calipers. Will include front and rear braided lines for another $100. Far cheaper and in better condition then 2nd hand GTR brake setups with essentially the same ability to handle thermal loads and essentially the same braking force (Pistons in calipers have slightly less surface area)
Will consider splitting gear, but really would rather sell as a kit for a guy wanting good brakes for the track. If you dont want all if it then maybe you can flog off what you dont need.
Front rotors - $350
Rear Rotors - $150
Front Calipers, pads and Adaptors - $600
Rear Calipers & pads - $250
Front & Rear braided lines - $170
More pics will be available after the weekend.
https://www.sau.com.au/forums/topic/167397-324mm-brake-upgrade-for-r32-gtst/
  • 2 months later...
Price is negotiable and will throw in braided lines to boot. Its a good budget upgrade for a GTSt, much cheaper then a GTR Brembo setup with what you can bet on beign rotors and calipers in far batter condition then you woudl expect buying used GTR Brembos
Bugger. Was hoping these had sold by now. Previous buyer pulled out after buying R33 brakes.
Willing to sell rotors and brackets so you can use your own caliper. Happy to sell calipers by themselves. They are sitting around doing nothing so best someone get use out of them
  • 1 month later...
i put the brakes back on the car as i didnt want to trial the new setup at a rally i was entered in. Problen is i cracked a rotor...good thing is i replaced them with brand new DBA4000 324mm rotors. So the kit now has rotors that have done some motorkhana work and a few laps of Winton and Sandown and less then 500kms.
Had a fair bit of interest but no firm committment. Will let the rotors go for the same price if they are bought as part of the front kit.
Any idea if this will fit on a 200ZR???? Cause I need new brakes but farked of I know what will fit! lol
I'd be looking at the whole setup if it does :closedeyes:
i got a 6/93 GTR R32... interested in front rotors... fit? im assuming so lol but always better to ask..
best price u can do? and location
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
