comes down to HKS 2530 and the Garrett 2860-5
while u pro's are still around, are the 2 HKS and Garrett "bolt-on" turbos without modification?
and where in Australia can i buy the Garretts from?
Snowman mentioned http://www.gcg.com.au , but they're offline so im not sure how much they are etc....
and thank y'all for the feedback/replies, very useful information (for me and im sure for others too)
Andy
  • Replies 78
they are both bolt on, but the HKS ones come with all the gaskets and new bolts etc. the garretts are just the turbos. and I have heard you will probably need to rotate the comp cover so it's on the right angle. the HKS ones come already set at the right angle.
I've run my GT-RS on both a standard capacity and now with a 2.8L crank.
As many have said (although not all), the set up on a 2.6L was really too laggy for my liking.
On a 2.8L, well that's a different matter altogether!
My vote is 25/30s for a 2.6L.
They are more than just re-badged.
There is slight differences in whe wheels used. Not a lot, but enough that they certainly are not rebadged.
Whilst Garrett makes the HKS turbos, thats where the similarity between HKS & Garrett turbos ends.
A little while ago this topic was discussed in great detail.....
All of the turbo's Made by Garrett came identical or a whisker short in the specs compared to the HKS ones.
The good thing is that HKS give you all the other goodies to go with the install...gaskets..washers...bolts...copper washers etc etc etc.......
HKS also have a special actuator...heavy duty that they have made especially for themselfs....but this is just to make a difference in the two product.
I believe the AWKW's compared to rwkw's is a strongly debated item in this Forum.
But I was told by many in over these last few years that awkw's x 1.2=rwkw's.
Cheers
so the 2530 is a re-badged 2860-5?
same make?
Fitted RB25 AFM's
Tomei Poncams
@ 4 Wheels
Max Power 274.7kw @ 6963 RPM (1.3 BAR)
Max Torque 924.8 Nm @ 4803 RPM
Max M.A.P. 230.4 kPa @ 4665 RPM
what is that equivalent to rwkw?
It is not just about how many.....what figures.....car doesn't have enough horses...etc..etc...it is not a dyno race..though some people think it is.
The car needs to feel right,handle well and not loose traction.....
I have a 0 to 100km an hour figure at 4.5seconds and the quarter mile at 11.8.
The car is driven everyday and I have chosen a safe tune with less boost(1.25 Bar) to make it last alittle longer.
Oh Beer Baron...sorry did not read your post...double posted all the goodies you get with the HKS kit.
Cheers...good luck with your venture
  • 10 months later...
hey there, i have just got garrett 2860-5 installed, r33gtr, as i replied in a forum a few days ago, the tomei dumppipes didnt fit up to turbos, custom piping, inlet to turbos (to fit air cleaner) and some intercooler piping all custom made. oil returns, water returns to turbos all modified, big money :laughing-smiley-014: will post some photos when car comes back........
Should have bought the correct turbos, the real -5 are direct replacement...done many times.
-5's and 2530's are different enough to make the 2530's perform far better infact on average the GT-SS perform better than the -5's.
-7's aren't the same as GT-SS either.
I had a quick look over some of the results (about 10 to 12 of each type except for the GT-SS , they seem to only just start to be flavour of the month) and did some totals of cars that are similar, standard capacity rb26's on pump fuel. I didn't include some of the hardcore 2530 setups like dirtgarage's to make it a little easy on the -5's.
The average for the 2530's is; 388rwkw
The average for the GT-SS is; 335.4 rwkw
The average power made by the -5's is; 313rwkw
Of the same data the best power of the -5's was 388rwkw
Best of the 2530's was ; 451rwkw (have an examples of a few a fair whack higher again but, left those out).
Best of the GT-SS was 364rwkw
going purely of budget un-opened/ non-built motors maybe with just some drop in cams it looks like this;
-5's average ; 298rwkw
2530's average ; 358rwkw
GT-SS average ; 332rwkw
-5's aren't bad but, then again they aren't HKS either.
HKS do enough to make the turbos work better than garrett's off the shelf. In some the case of the -5's it's a few mm or fractions on the inducer /exeducer and trim, basically a different wheel made just for them. They also have their own housings at least on the compressor side and sometimes as we know the exhaust housing too.
  • 1 year later...
I thought the GTSS is similiar to the N1s?
Anyway, i've got 2860-5 and 2860-7s for sale :)
i need a bolt on, and injectors and rail, for my 33 up to that stage now,
what way shuld i go and costing if some one knows????
have wolf v4 and all other bolt on u need, need fuel pump az well
thanks for any help
  • 5 years later...
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
