Evening All,
I'm getting some gauges to put in for my R33, what should I get.. i'm thinking Boost, Oil Temp and Oil Pressure.. however i'm weighing up swapping the Boost for Water Temp as I have a turbo timer that doubles as a boost gauge with a memory for max boost (which isn't overly helpful).. I'm looking at the Just Jap Autogauges..
I'm looking at doing some track days.. And think that oil temp + pressure are pretty neccesary..
Also i'm guessing it would be better to get ones with warning functions..
Any thoughts would be great as I need to order them tomorrow morning to get them in time for the weekend to get installed!
Cheers
Links
https://www.sau.com.au/forums/topic/168010-what-gauges-to-get-done-autogauge/
water temp oil pressure (get boost if you done have a elec boost controller for read out, not sure how accurate the tt is if it is then thats fine but hard to see)
oil temp
exhaust temp
fuel pressure
get them in that order, first 2 lines most important really
Edited by GTR1993
water temp is deffently good to get as the stock one isn't spot on. Oil temp is helpful, not only on the track, but when u get into your car in the morning, you'll know when the oil is at the right temperature to boot it. Ane oil pressure. Thats my 2cents.
Ok cheers, so from what everyone says, water temp, oil temp, oil pressure... Looks like that's probably the go than.. I can get a boost one later as my stock one and turbo time are pretty much in line with each other and seem to be fine..
Has anyone used the autogauge ones with the warnings? are they configurable warnings...
Update, I went with the 3 din package from JustJap with oil temp/water temp and boost, i might get an oil pressure one seperately at a later date if I feel I need it..
I'm heading to thailand in september, so might pick up some decent ones over there to replace these!!
Cheers for everyone's help, I think Oil Pressure + EGT will be the next ones to get, OR get a digital readout that can display all of them..
Ok the gauges have arrived, now, I got oil temp + water temp + boost..
Question is, in an R33 gts-t, for the water temp, do I just unplug the stock sensor, or can I run them both at the same time? What do other people do? Does the ECU need the water temp sensor to be plugged in??
ecu water temp is needed to allow for cold start maps.
most people use a alloy fitting in the top Radiator hose that has a threaded insert so the temp probe can sit in the water flow.
most A/M guage probes dont fit in the std dash guage sensor location on the intake manifold.
best bet is a generic or Greddy adapter that can be put in the top hose.. i made one up just using alloy pipe - not as pretty as the alloy made ones from greddy etc
Thanks guys, Ronin, i'll send you a PM..
Cheers Chris, I had a feeling the water temp was needed for the ECU as it's one of the readouts you can get from consult when your reading off the OBD..
For the boost, i'll just add another T piece into the line after the one for my Turbo Timer.. Oil temp just goto get a sandwich plate, anyone recommended other than Just Jap or should I just get a remote oil cooler..
Links
yeah i was sick of cheap gauges not being 100 true, so i paid a bit more for these. these are the exact same as the SABER gauges with a different logo on them. they have the same hardware and bits in the box as the saber ones also. just 100 bux cheaper than saber.
mate they look good, I want something that matches the stock R33 gauge cluster and they suit it well
what is the gauge on the left? Oil pressure/Oil temp?
just wondering how you go about hooking up the Oil Temp and Oil pressure gauges?
gauge on the left is oil temp. i used to have oil pressure but i believe oil temp is better for a daily driver.
i have an oil cooler and relocation kit so i just screwed the sensor into the remote mounting block, the relocation kits really are great for many reasons.
water temp gauge is wired into an inline radiator hose sensor.
^^ Did you use the existing water temp sensor? Or the one that came with the gauges? Can you use the existing one and wire off it?
I'm going to use Ronin's Greddy radiator adaptor that has a plug for it..
Next question is:
How do you feed the wires through the firewall of a R33, do I use a coat hangar or something? Do I need to remove the kick panel to access it?..
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
