hey everyone,just a few things about my s1 stag i need help with,there are a few things so whatever you know would be good,ok first is the switch to the right of the steering wheel with a pic of a window and wiper,when switched a red light comes on,what does it do haha,
2-the clips on the passenger side along the side,whats that for??
and 3- has anyone else had trouble with headlight globes and plugs??my plug has kind of melted twice now(by kinda i mean a melted a little)
any help would be appreciated,thanks
UPDATED! does anyone in perth know where there is a car yard that will do trade in on my stag or will buy it out right,i have been trying for 2 months as auto trader readers would have noticed...and hav only had time wasters,thanks
Edited by stagpower
https://www.sau.com.au/forums/topic/168194-help-needed/
1. Unless I'm very wrong, the wiper controls should be on the LEFT of the steering wheel, and the rear window wiper should be on the same stalk as the front windscreen wipers. On the RIGHT of the steering wheel is where your indicators and headlights are, so I'm guessing that other switch is you turning on your fog lights (the yellow ones).
2. What clips are you talking about? Your question is too generalised - maybe take a few pics or give us a better description.
3. If the plugs on your headlights are melting, maybe take the car to an Auto Electrician to sort that out...
https://www.sau.com.au/forums/topic/168194-help-needed/#findComment-3109998
is the switch to the right of the steering wheel with a pic of a window and wiper,when switched a red light comes on,what does it do haha.
If it is wiper related, you might have heated wipers?!?! (was that an option?)
Useful in Japan where the wiper blades could freeze to the screen or even become hard and frozen in extreme conditions.
https://www.sau.com.au/forums/topic/168194-help-needed/#findComment-3110212
^ thats usually able to be seen as it is a demister strip like the back window one running along the bottom of the windscreen - they heat the glass not the wiper blades (being made out of rubber and/or silicon they wouldn't respond to electrical heating real well....)
picsorban?
https://www.sau.com.au/forums/topic/168194-help-needed/#findComment-3110666
Is'nt it quite a tickle when you buy a vehicle that does not have a set of operating instructions?? LOLLOLLOL
It took me at least twominutes to find the hand, err, foot brake. I still have a laugh about it. And not being able to get the stupid rotten sod out of park without putting your foot on the foot brake. I'd had heaps of autos and that was a first for me.
I guess it is allpart of the Stagea Saga.
I luv em.
https://www.sau.com.au/forums/topic/168194-help-needed/#findComment-3111752
my mates lx torana had the foot hand brake because it had a bench seat. if you want to do a comparison shane drop round after work,
yeh sounds good,will organise with you one day,will you be at the stag cruise?
https://www.sau.com.au/forums/topic/168194-help-needed/#findComment-3111972
2) If you are referring to the 2 clips on the passager side foot kick panel, they were used to hold the road side emergency flares back in japan... alas I reckon only about 40% of cars arrive here with them still attatched...
Me thinks they get taken along the way for people to have fun with :D
https://www.sau.com.au/forums/topic/168194-help-needed/#findComment-3112051
^^^Yeah. I have owned a few imports now (all Nissans) and have never had the pleasure of getting the factory flare. But a work friend just got a mint R33 and it came with the flare. Nothing special really I guess but its pretty cool just to get one. I probably wouldn't want to use it though just to keep it there :D Mind you, it would probably fetch a bit on Ebay :)
Edited by Mr_RS4
https://www.sau.com.au/forums/topic/168194-help-needed/#findComment-3112094
I got these 2 thick (one red and one green) manuals in a red stagea folder when I got my car. Heaps of stuff in them but since they're all in Japanese I can only look at the pics and try and make sense of it. I remember seeing a pic of that switch before and it pointed to something to do with the wind screen. I assumed it had something to do with heating it as well. But I have never been able to test it out!
https://www.sau.com.au/forums/topic/168194-help-needed/#findComment-3112213
i converted my flare clips into a mag lite style torch holder and its kind of a handy spot to keep torch too cos it will usually be the passenger that is req'd to hold one anyway, only thing was that the clips are a touch small for a "MAGLITE" but some other equivalent brand torches will fit straight in them.
or you could just buy the proper maglite brand clips and install them in the originals place i spose?
cheers oxford
https://www.sau.com.au/forums/topic/168194-help-needed/#findComment-3113071
  • 1 month later...
Leetom is correct, the "Wiper de-icer system" usually came with a cold weather spec pack which also included heated wing mirrors, rear fog lamps & if you coupled that with the "S Pack" you would get a rear viscous Limited slip diff (LSD)
https://www.sau.com.au/forums/topic/168194-help-needed/#findComment-3188280
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
