  • Replies 199
Posted Images
looks like a top event. sorry I had to quietly opt out and didn't make it down.
Instead I stayed in nsw, got work done on friday, then brisbied my car at eastern creek on sunday :) looks like I would have been better off at deca.
Dude this sounds bad what happened????
basically
poor set-up rear end (was trying new set-up, but 8kg springs + 28mm sway bar = no rear end grip).
poor driver
snap oversteer
concrete wall
basically
poor driver
snap oversteer
concrete wall
Ouch dude.... least it wasn't tooo bad!!! Kisses u can handle hits hurt!!!
I missed this before.....
Heh thanks to the late night crew as well, was good fun!
Im not sure if Id call it a late night, or an early morning!!
But agree - was fun.
Oh yeah.... and next time, im taking your credit cards too :) - your just as bad (if not worse) than the Bris.
rest of the vids have finally finished uploading:
http://decamay07.racemeets.net/
so basically if u hit the skid pan in either of the morning sessions you should be there
cheers
thanks for the great vids. nice work
cheers
Thanks heaps for posting the vids mate, they are great to watch. I liked the zoomed in take off shot on one of my runs :D
Cheers
Ben
