....Its very cheap....maybe too cheap....
!!HEY! its looks like this car too!!!
And heres a thread for more info on that car - it was for sale a while ago, who can forget those yellow rocker covers and purple belt n cam gears...
http://www.skylinesaustralia.com/forums/in...161013&st=0
https://www.sau.com.au/forums/topic/168813-sigh/#findComment-3122466
got a phone call from this guy today as i like many others were very interested in a 20k+ package for 3k. he said he would post but wanted the money up front first. i called CRD to verify the engine build and owner name and car rego, they have never heard of him or the car that he said had just been dyno tuned! dodgy good luck to who ever buys this but the story he gave me always changed when i spoke to him proceed with caution!!!
those pictures just confirmed my suspicion notice too he has only been a member since the 13th with 1 post.
food for thought boys
https://www.sau.com.au/forums/topic/168813-sigh/#findComment-3122817
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
