Hi guy's
the below dyno sheet is my car with r34 N1 turbo's is this how they are supposed to respond i do have the bigger N1's turbos C106/GT25 A/R 0.60/0.64. but it just doesn't seem like it's that responsive compared to other people's dyno sheets, with what i would assume are bigger turbo's. it seems to be much laggier than the gt-ss or could the laginess be caused by something else??
and what power are other people making with this turbo I'VE DONE THE SEARCH but have not found any dyno results for the 0.60/0.64 N1's as i am chasing about 350rwkw
the mods on the car are
ACL Forged Pistons
ACL Piston Rings
ACL Big End Bearings
ACL Main Bearings
Ported and polished head
Stock polished crank and rods
Bored and honed Block
N1 Oil pump
N1 Water pump
Tomei Oil Gallery restrictor
Gates timing belt
New engine gaskets all round
New Thermostat
New NGK spark plugs
R34 GTR injectors
R34N1 turbos C106/GT25 A/R 0.60/0.64
New Rod bolts, welsh plugs
Fresh paint on rocker covers
3" Trust Front pipe and Power Extreme II Cat back Exhaust
3" Metal cat
Twin Apexi Pods
Apexi Power FC & Hand Controller
Greddy Profec B Spec II boost controller
Nismo fuel pump
still to come
Cam gears
injectors
That is 247@ all 4 wheels on 14psi.
r34 injectors - get some decent ones in there, 600-700cc's
do you have cams? cam gears? how much porting was done to the head?
also it's a bit on the rich side. lean em back to 12:1
no question of a dodgey tuner at CRD either :D
also how old is the motor?
yea that's true but are they supposed to be this laggy
without cam gears. yes.
Its hard to say "are they meant to be this laggy" especially when 999 people out of 1000 have installed cam gears along with upgraded turbos
mines about the same 3000 before any real boost starts to happen and i am using the 2860-5.
Cam gears did make the difference though.
when i say 3000rpm that's when it starts making positive boost (like 1psi or less) on my boost controller and then full boost which is 14psi at over 4500rpm
to be honest i have a 180sx which makes at the moment under 200 rwkw and feels alot faster than this gtr there's no real surge of acceleration when on full boost it's seems like it's very liner power which is strange looking at the dyno sheet
the car was dynoed with 16inch rims 225 wide does anyone know how to convert that to rpm??
the motor is about 9 months old and i am going to get cam gears but before i install them i just want to make sure that everything else is ok.
i bought the car about 2 months ago and it came with that dyno read out so i just want to see if anyone else that has these turbos is getting the same response as me
firstly they are " group A turbos " as they have a .60 comp housing and not a .42 which is the main visual differnce between them and the N1s, yes they going to be laggy as they are bigger turbos, cam gears will help alot, i personly got my turbos two come on full boost 500 rpm sooner from just fitting turn tuning cam gears on the track by feel and when i had the PFC fitted CRD tuned them more, also in the exhuarst did change the dump pipes as there good gains in boost responce form them too.
oh ok but they are the r34 group a turbo's right??
what hp are they rated at and what hp are you making???? and when do you see full boost and what psi is it??
Cheers
anthony
34 N1's come in two sizes :)
And to add to all this business about cam gears etc i dont have cam gears yet i have a very responsive machine!! Maybe its about time i invested!!!
now to add some more... i remember these fitted to a rather standard 34 vspec 2. he complaned about them bieng too lagy so they were swapped for the smaller N1 items.
i beleive there needs to be alot of supporting mods for the larger ones to be in their range. and a bit more boost :laugh:
Edited by Angus Smart
here's what you need to do:
get bigger injectors (440cc are just about run out with what you have now)
change AFMS to nismo or VG30s
get cams or cam gears or both
raise boost to 1.5bar
spend time tuning the boost controller for best response
so fit the cams/gears, injectors and afms. then take it back to your chosen tuner and have it re-tuned and the cam gears set-up.
post up your IGN and INJ map
just view on the hand controller and punch it into an excel spreadsheet
should take you 5 minutes
then we can see your maps and see how its tuned
will give away lots of info
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
