There's 4 very good write ups with pictures on this site. Everything is in them.
Take your time and take mental pictures or physical ones of everything you haven't seen before or are unsure of as it will help when putting it back together.
have the correct tools handy. Get a balancer puller that uses the two m6 holes to pull it off.
Melbourne, Northcote area. I have had a look at the step buy step procedure, I guess i am just not 100% in lining up the timing belt marks.
You'll be fine :) it's so simple. Wind it over and watch the cam marks and that they align, then check the crank. Done.
Question, once I have aligned the the marks for inlet,exhaust and crank, i then remove the tensioner, once the tensioner is removed / released ,will the belt want to move the cams from the original set location because of the tension lost ? if so how is this avoided or rectified?
one other question, just to clarify, the harmonic balancer retaining bolt is L/H thread or R/H?
Balancer bolt is normal thread. Righty tighty lefty loosey. There are a few ways to undo it.
Cams won't move, they're locked.
I'd advise looking at all Diys we have on this website and getting a good idea on how to do it.
Maybe someone here who is close to you can come and help too
People tend to stuff up the tension, usually too much.
Definitely do camshaft seals, and crank seal.
Yep I did, I guess?.
The gates belt is a LOT stiffer than the genuine and dayco belt, so at the same tension of the original, the gates felt a little loose. I did it up a bit tighter and it whirres
Just a quick question fellas,
I changed the timing belt on my r33 s2 det last night, all went reasonably well.. This morning i took if for a drive and every thing seemed fine until I entered the freeway and opened it up a bit, as load and pressure built up above 4.5-5 rpm + It seemed to bet a significant loss of power, now I would also like to mention that I have upgraded the turbo due to the turbo spitting it self the other day, the up grade was from standard - to a Garrett T3/T4 Hybrid A/C CHRA Conversion. (Car not tuned yet)?
is it a possibility the crank angle sensor could be 1-2 mm off even though i make it? or is it just running very rich etc..
I know this is not the right topic , a link to the correct topic would help or some insight would be appreciated.
Edited by Antek
I don't know much about that turbo. But have been in a few skylines with upgraded highflows and bigger turbos without tunes and they are slow and shouldn't be driven hard until you get a tune.
Did you mark the cas before taking it off?
Should check your timing with a light anyway because no mark will get it back to spot on. A small movement on the CAS is big in degrees, you could be up to 10' out? And that makes a huge difference as well, even 5 is easily noticeable.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
