lol loving auto-tune
*expletives deleted*
while t-pain uses the autotune a lot, its a pretty damn obvious use of it for the sound effect
the thing that shits me is when you get turds like britney and ashlee simpson using it, hell, even t-pain can sing without the autotune, he just calibrates it really roughly... when they use it on girls (lip synchers i should say) like britney etc its tuned much tighter.. thing is that shit is destroying the music industry from within. i'd be outraged, if it wasnt having a spectacular blowback effect upon the listeners and the industry..
point in case.... black eyed peas
not many people know this, but back before they got that post-methamphetamine scrag fergie, they used to be one hell of an underground hiphop act.... download 'bridging the gaps' and 'behind the front' if you want to hear the black eyed peas before they sucked... as soon as they got fergie, they sold out and focused upon selling records rather than producing real good music, and for that they should be vilified and hated for the sell out capitalist cops they are... sadly, I have to confess that I did infact download their subsequent albums, and after listening to each one, I deleted that herpes infected shit off my hard drive before my entire computer caught cooties
i downloaded their latest cd, and the entire f**king thing is saccharine pop bullshit, each song uses the autotune, even in places they dont>have< to.... I felt raped from having downloaded a 60meg zip of their album, and I felt noticably dumber after having listened to that POS....
Moral of the story, autotune = shit at best, apocryphal at worst, same goes for the black eyed peas. they used to be down, now theyre just sell out clowns
-D
too late for political/religious debates we each know where we stand ;)
one does not need to believe in a deity to believe :D
Belief in ones own self is necessary for a human being to truly live free
-D
no i see it on bumper stickers all the time so there must be lots of believers :D
that white thing in the corner? is that a map of texas?
> I BELIEVE IN TEXAS! <
oh i feel the rapture-a-comin >;)
=D
Edit - srsly tho, I did 4 yrs of theology and i can appreciate the subtleties including the use of the color purple, the saying itself goes much farther than religion, its actually a psychological profile of human nature - belief of anything that is greater than ones own being inspires acts of bravery, madness, stupidity, love, dedication and cold hearted resolution....
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
