Pretty silly leaving the Victorian number plate on you can see the rego in one sceen. Looks a bit stupid in the back streets. Hope he dosen't get caught.
But yes it did look good on the roundabout.
^^^ and sadly powersliding is NOT drifting. It's like nearly every Yank Youtube video about 'drifting' - none of them clutch kick or handbrake - they are only powersliding.
Your a day layour a day late with that one ;)
I know it was an April Fools joke they did, I didn't know about that one till today, I still found it amusing so thought I would share for people that didn't know also.
this is great
first they convert a car turbo to work as a primitive jet engine
then they screw around with a Rolls Royce Derwent engine in the backyard of their garage...
Makes me want one. Just cause
-D
saw that awhile ago Ben....awesome!!
Here is the follow up video....apparently Karl passed away just over a year ago
This is an interesting reply to a question as to "why doesn't the truck move at full throttle/"
He could have 50 of those engines at full throttle on the truck and it will not move, UNTIL the brakes are released and then there is not stopping it! Ever seen the video of the 'strongman' holding back a whole jet with his teeth are something, if he gave the jet an inch he would be gone. Even when you are flying, the jet will full power the engines and those tiny tires hold it all back, until the brakes were released. if Carl released the brakes on the truck, no stopping it!
I will have one of these in a year or two.....shame it'll cost $40K to convert it to RHD.
662hp Mustang Shelby GT500 for under $100K
Won't beat the R35 around the "Ring" but will blitz it in acceleration....apparently the 2013 model will out accelerate the Bugatti Veryon.
Listen to the sound of the stock exhaust!! :woot:
http://youtu.be/kqx0YzQEATI
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
