Hi
Seems that the email notification that ive set to receive when i get a new pm isnt working.
Have changed email accounts a couple of times to see if it was a problem with a specific account, however all receive the correct email change confirmation and i can confirm the email change.
Thanks.
Damone
https://www.sau.com.au/forums/topic/169759-pm-email-notification/
  • Replies 74
Posted Images
I made a quick change to your account which I'm hoping will fix the issue, IPB had a bit of a dummy spit when I hit save but the setting seems to have been stored ok. I double checked and there doesn't appear to be a problem with your account so it might have just been a once-off error.
I've sent you a PM too, so assuming you're subscribed to this thread, you should get two notifications :domokun:
I had a smilar problem when trying to activate my account. I entered my personal e-mail address (one hosted on my own domain), and never recieved the e-mail.
Changed my address to @gmail.com and got it right away.
Just letting you know :ermm:
I am getting no emails from SAu, none.
Revhead just sent me a PM and I got nothing, I am on gmail as well.
So sent an email from my work to home, and I usually get it nearly instantly, took 10mins, suspecting it is a gmail issue? But at least I got it............
Sent from gmail to work, got nearly 2seconds after I hit send in my work email.
Yeah nothing here either, newbie101 went to reset his password, not realizing that he wouldn't get an email, lucky Revhead to the rescue and reset his password, that was this morning, sorry for the bad news.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
