Remsa are quiet and good performance but very dusty.
Just a quick update on these, they had their second outing at Sandown on a 37 degree day on Sunday. Really happy with the hot bite and lack of fade (though had to do a lot of cool down laps because of oil temps so brakes got a rest too).
There's about 4-5mm left on the fronts after maybe 10000kms and two track days on a full weight GTT sedan.
Besides the crazy dust the only other thing I'd note is the somewhat vague feel when cold.
Still, recommended, especially at this price point.
Try Project Mu HC800 next time, it will blow your mind away and maybe your load too.
Those who rave about A1RM have never tried anything better. like a guy that's only owned a h0mosexual Honda Civic will say his car is the fastest thing alive.. till he or she hops into the likes of a Skyline and cream both their front side and back side openings.
Yeah I know, but ~$110 vs how much for Project Mu?
  • 3 weeks later...
Had to post this here;
Brakes Direct/GSL Rallysport do an amazing job! I ordered my parts yesterday morning, and they arrived this morning. Overnight parts from QLD to ACT.
Ordered some new TRW GP600 Brake fluid 1L to do a flush. and some Remsa/Roadhouse pads for the front to match my already existing remsa rears.
All that's left is a new RR caliper as the one i have has a stripped fluid hole, and a lick of paint.
I'll be able to report back on how they go on a heavy stagea at the track in april.
Setup consists of; R33 gtst calipers - DBA 4000 T3 rotors F+R - Remsa/Roadhouse pads F+R - TRW GP600 fluid - Nismo braided lines front - APP braided lines rear
  • Like 1
+1 for Brakes Direct/GSL. Ordered new Remsa fronts for $85 w/ free delivery on Tuesday night, received them on Thursday. Awesome.
Also as Trex and some others have pointed out they're currently supplying Roadhouse instead of Remsa. It's still the same pad, compound and part numbers.
  • Like 1
Yeah, did a bit of research on this a little while ago :) Hmm I paid $10 more than you for my front pads :/
Yeah no idea why they are $95 at GSL and $85 at BrakesDirect, it's the same company?! Anyway, go cheapest :)
  • 3 weeks later...
Screw Remsa, I got them on my GTT after hearing about them here. Never ever saw pads that spit that much dust in my life. Rims get absolutely coated with brake dust in a week. And the pads wear out quick. Cheap nasty shit, never again.
But you were warned that they are dusty lol. That's what everyone says. "they are great, but dusty" lol
haha this. I prefer to spend the extra 5mins each wash instead of paying $800 for new rotors.
So how did they actually perform on your car?
Even China shit cant be as bad as these.. :(
Hahahahaha. You don't know China pads like I do. You also didn't mention anything about the performance, just that they are dusty so they're shit.
Maybe check out Bendix General CT?
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
