Hi all
I have a thread in the WTB section here: http://www.skylinesaustralia.com/forums/in...=170351&st=
Does anyone know of any genuine AUS R32 GT-Rs for sale - or at least a few things to look for to know if it's a genuine one or not?
Thanks
James
https://www.sau.com.au/forums/topic/170352-aus-delivered-standard-r32-gt-r/
basic things to look for are:
rear number plate surround does not have reverse lights either side
outer rear brake lights are also the indicator and have an orange lense
they have the under car coolers too, but these have sometimes been removed
Marcus will be able to tell you what makes an Aus GTR an Aus GTR. I saw one for sale in NSW not so long ago for around $40K. It was stock.
interesting - evo for sale, and now aus delivered gtr? unless, this is going to go to p1 international :O
edit: wasnt there another aus del r32 gtr on sale here toward the end of last year or something? not sure if it was in vic or not..but was a silver one i think
post the differences butt munch!
this one looks ok:
http://www.carsales.com.au/used-cars/priva...matchallpartial
this is the one for sale on UAS too. A bit less desireable I reckon as it has twice the kms and more mods.
I take it I am butt munch then...
0. came only in Black, Red and Silver
1. side repeaters same as aus 300zx (long) and probably clouded now (deleted on my car now)
2. roof mounted antenna which is rubbish (deleted on my car now)
3. probably has nice 'nissan' mudflaps
4. transfer case cooler near rear diff (mine busted and gone)
5. rear lights different - outer circles are indicators, square between circular lights is reverse, inner circle is brake
6. 260km std speedo - no GTR markings or anything (by memory)
7. additional dimmer switch on RHS of dash cluster for dash lights
8. rear high mounted LED brake light (in top of window)
9. kid seat mounts in parcel shelf
10. obviously a "Nissan Australia" build plate on the LHS (passenger) of engine bay behind ABS unit
11. plastic trim piece that covers the rear number plate area and is the full width deleting the reverse lights there (part no longer available from nissan so don't get rear ended!)
12. nissan badge on bonnet instead of "S" badge
Ask and you will receive!
AusGTRspecs.pdf
There was a RED one for sale a while a go by one of our members too, he was at the Show and Shine that SAU VIC held at South Bank!
I decided to keep it. Even thought i don't drive it much any more. :P
Don't have the time
make sure there is the orig dealer log book too.
Edited by Zardos
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
