How Old Is The Average Sauer
172 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hi,
It has crossed my mind, the thought of how old everyone on here really is.
So I thought I would try and find out. I have included a Poll so we can all see the results.
Thank you,
Regards
Edited by paulr33
https://www.sau.com.au/forums/topic/170497-how-old-is-the-average-sauer/
  • Replies 40
so far im the only 1 under 18? :(
If you already own the 33, i hope you get your licence b4 1/07/07 :P
I guess even if you do get your licence b4 1/7/7, you run the risk of a $1100 fine and 3 dimerit points, for every time you get pulled over, for the next 3yrs :/ .
hes got a non turbo sedan if my memory serves me correctly.....
but hate to be those 18 year olds that will be getting the fine and loss of points for the next 3 years! good luck to them
yeah mines a not a turbo, only reason being what you guys have stated, $1k fines every time i'd get pulled over. Although even with a non turbo once ive done some mods to it the cops will most likely pull me over anyway to check it and i can laugh in their face.
Oh and getting my P's 18/07/07 hehe.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
