to all of those people supporting the 255lph walboro pump - they are shit. You need to get the Walboro 255lhp HP version. The high pressure version handles pressure a lot better than the standard 255 one. The standard one is for a NA car.
And I Don't care what you all say - I have one, and I have seen what they do. As soon as you up the boost beyond 10psi, you are playing with fire. The pump can't handle pressures above 50psi very well at all.
Standard fuel rail pressure - 42psi + Boost (10psi) = 52psi.
As soon as this pump reaches 55psi - 60psi, the flow drops dramatically.
Have a look at the Blue line on this flow chart -
I picked up a brand new genuine Bosch 044 pump off ebay for $204.50 + delivery. Going to mount it externally in the boot and draw through the standard intank pump which my mechanic assures me is fine.
So are you saying my mechanic is a liar? personally I would take his word over some random on the internet - no offence :)
Does your mechanic deal with much performance stuff? When it comes to performance some mechanics dont know there arse from their elbow, all they know is servicing etc etc standard stuff.
Talk to a performance workshop or fuel systems shop. Theyll tell you the same thing.
He has a 10 sec RB30DETT powered VH that he built himself, does that qualify? I also went to school with him and he is a very close friend :)
I had the same thoughts as you when he first told me to mount it externally, he assures me it will be fine. Either way, he's putting it in so if it doesn't work he can redo it .
Edited by bubba
I dont understand why people insist on fitting fuel pumps in the boot, its illegal for a reason, people do die from cars catching on fire. Ever wonder why there isnt one car that is complied that has the fuel pump in the boot?
its because the mechanic is lazy...... simple as that.
My walbro one is already installed, so i cant check if there/where any numbers on the side. .
however on the box, it says..
10258
Walbro High Flow Intank P
<barcode> JE04
10258
So can anyone confirm which model i got?
cheers
Edit: found it:
Cool i got the HP version!! the GSS-342.
Edited by siddr20
Hey champ,
16 is not really a good air/fuel ratio! in fact thats really really lean. I would suggest a fuel filter change, injector clean, and possibly a fuel pressure reg and DEFINATELY a fuel pump. There are a few around 040 bosch, walbro or nismo or gt0r pumps. it really depends what your power goal is. A re-map of your ecu or a piggyback fuel computer like a SAFC1/2 or a Neo will help harness those ponies.
My r32 gts4
rb20det
rb25 highflow turbo stage 2
splitfires
remap
fuel pressure reg
3 inch exhaust
stock bov
FMIC
Boost 16 psi
AFR 12.5
gt-r gearbox
exedy HD clutch
158.5 aatkws
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
