i jst got a new set of 15" retreds, and i was told that it aint a good idea to go ova 100km/h with em on....otherwise you can lose em....is it a good idea to put in new tubes or is the myth true and i shouldnt go ova 100 on a regular occasion?
DK
https://www.sau.com.au/forums/topic/170963-re-treds/
actually it's not a good idea in my book to go anything over about 40km/h. re-treads should be illegal. buy some good tyres. 15inch tyres are cheap as chips. for $500 you could get some decent tyres that will probably last 5 times your retreads and they will handle well, stop well and you'll have more fun driving.
https://www.sau.com.au/forums/topic/170963-re-treds/#findComment-3154818
hmm and only just then....we had retreads on the car trailer when we got it and blew all 5 within the first 3 months...bloody frustrating changing tyres all the time.
Anyway, there are cheap and OK tyres available, have a look at the "what tyres have you used" thread in here
https://www.sau.com.au/forums/topic/170963-re-treds/#findComment-3157211
have u ever seen a retread?. i was considering gettin them on the bak of my 33. i got it wit 1 15 inch spare with a retread. i had no idea thats how they did them and what they looked like. they suk. u can get 80 percent brand name 15s for 30-50 dollars. even cheaper than a retread an 1 million times better.
https://www.sau.com.au/forums/topic/170963-re-treds/#findComment-3162747
re-treads are for ..... actually im not sure what they are good for :P
My old ladys old ae82 had retreads all its life, mind you the car was a piece of shit that wouldnt die minus the fact that if you could get to 100 in it you had a down hill and a long stretch of road.
https://www.sau.com.au/forums/topic/170963-re-treds/#findComment-3162842
Retreads are dangerous....
I remember as a young lad looking out the back window at the trailer while we were sitting on 100km/h down the freeway with a trailer on.
I saw the tread peel off and slap the guard as the tyre rotated. It took 2-3 slaps before the WHOLE guard of the trailer was removed. Amazing to watch.
Soon after that the trailer started to sway and the next thing I can remember was the arse end of the car being picked up and the rear wheels chirping as it swayed from side to side. Old man slammed the brakes and luckly we pulled up fine.
I ran a set of retreads once and had them removed as it felt as if the car was going sideways on 80km/h sweeping bends.. lol apparently it was the tread shifting on the tyres carcas. :S
Don't run them. You can pick up new tyres for cheap as these days.
https://www.sau.com.au/forums/topic/170963-re-treds/#findComment-3162850
What I don't get is how the NSW Government can bullshyt on about trying to make the roads safer by banning P platers from driving "high performance cars" (like the entry-level Mercedes C180K, with its neck-snapping 105kW), yet its still perfectly OK for them to roll around in an old non-V8 Falcodore on retreads.
The only thing retreads are good for is paddock bashers. On a road car, they should be illegal.
https://www.sau.com.au/forums/topic/170963-re-treds/#findComment-3162901
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
