  • Replies 233
doodz
SV7795978
That's your Express Post package number.
Call your local Post Office and give them a razzing.
According to 13-13-18 Press 3 then press 4. The person said that it was "delivered" on the 21st Aug 2007.
However I have not recieved it, nor have I gotten any slips re "Notice of pickup" from the local post office.
I asked them for the direct number for the local post office they said "because it is private we cannot give that out"
I wil have to take time off work ~1hr and physically goto the post office to check and "maybe' it will be there.. Which in turn I'll lose money because Im not working....
GRRR
Bass this isnt directed at you. It's for my local post office, they are a bunch of wankers and I want to send them anthranx and bomb them.
Edit: I was able to locate the direct number from other forums and rang them and they do infact have the express post at the post office.
Thanks!
Installed my silicon intake pipe last night took me 3 hours from start to finish,
Fits nicely after a bit of trimming to the two little holes.
I've got it fitted with a Mr_Crust airbox and the silicon was flexible enough to refit it in the mr_crust airbox so i'm happy :) i'm sure others that have pod filters who need the intake pipe to bend enough for the pod bracket to be bolted back on shouldn't have any issues either.
Anyone have final pics of the product ontheir cars?
Installed on weekend. Still using standard airbox. Mind also needed trimming on all inlet/outlets.
  • 2 months later...
Guest
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
