Do not use the q45 90mm throttle body. It's not made for supercharged applications and the seals around the throttly axle will leak boost pressure. I've bought 3 tb's and tried before I gave up. They all leak after 0.6bars og pressure :thumbsup:
That seems strange, as even the genuine greddy manifolds are drilled to suit them, there are 80, 90 and 100 mm anodised throttle bodies on ebay for under $300 new
My local rod shop supplied me with a machined billet number that sure looks the goods. A tad over 300 dollars from memory. and its 80 mil. It doesnt bolt directly to the greddy plenum but it wont be difficult to make it fit. :bunny:
I looked for ages for a q45 and gave up trying to find one. When you do they sell for around the 250 dollar mark anyway so I figure for the bit extra its worth it to have the new one. :thumbsup:
i think that the standard trottle body will be a restriction to make the 350rwkw in my rb so im just doin everything slowly and getting everything over a period of time all those billet ones on ebay are in chine and i can get better quality from here and its aussie made "support aussies as much as possiable" lol
pretty funny while driving a jap car haha
I used an 80mm throttle off a q45 v8, it bolted on and was half the price of a shiny billet one
i cant seem to find a q45
I've got one for sale on the Gold Coast in QLD, happy to post if you are interested shoot me off a PM.
Do not use the q45 90mm throttle body. It's not made for supercharged applications and the seals around the throttly axle will leak boost pressure. I've bought 3 tb's and tried before I gave up. They all leak after 0.6bars og pressure :)
I agree that does seem strange, ive used one on my car for over a year (490hp @ 1.2bar) with no issues or leak what so ever.
  • 1 month later...
hypertune ftw!!!!!
I just had a bad experience with a HYPERTUNE plenum for a EVO (real animal with well over 300awkw), awesome plenum but overpriced and required ALOT of work to fit.... and the HYPERTUNE throttle bodys are flat out junk.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
