Haha... I took him to pick up the car this morning :/
Its an awesome car... took it for a test drive and I love it... has made me want to upgrade from my gts to a gtst :)
Congrats man... guess I'll see you around the forum a bit now :P
https://www.sau.com.au/forums/topic/172104-my-new-car/#findComment-3169971
Definitely looks nice and clean. Getting a new car always rocks, especially if its one you've wanted for a while.
All you need now is a bodykit, a front mounted intercooler and a blow-off valve and you should be set for a while.
Someone look up the definition of 'Rice Boy' for me.
https://www.sau.com.au/forums/topic/172104-my-new-car/#findComment-3170162
Hi guys,
Thanks for all the nice comments!
Firstly I'm only 17 and will hopefully have my license soon lol. Ive been working and saving hard for about 2 years, and owning a skyline has been my dream for a long time, which has finally come true :)
The car is a 1995 R33 GTS25T Series 1.5.
As for plans, at the moment I would like to get a nice set of rims probly some volks, a full turbo back exhaust and a better stereo system as the car is COMPLETELY STOCK. In the future I would like to either go a Tomei 2.8L stroker with the RB25 or do a RB30 bottom end with a 25 head. I'm thinking the Tomei stroker cos I'd like to see how far the RB25 head and block can go. We will see what happens, other than that all the other usual mods.
Once again thanks for all the nice comments, I look forward to meeting you guys and learning lots off you :P
ob1: Just Car insurance
https://www.sau.com.au/forums/topic/172104-my-new-car/#findComment-3170780
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
