HI THERE,
JUST AFTER SOME PART NISSAN PART NUMBERS FOR A R32 GTR 90' MODEL.
1. THE RUBBER SEALS WHICH GO AROUND YOU ROCKER COVERS - PRESUME THEY MAY COME AS A KIT BUT COULD BE WRONG ON THAT ONE? AND
2. THE REAR GEARBOX RUBBER MOUNT, (HOLDS THE GEARBOX AT THE RIGHT HEIGHT BETWEEN WHERE THE BAR GOES ACROSS THE CAR IN THE MIDDLE AND THE BOTTOM OF THE REAR OF THE GEARBOX).
MANY THANKS IN ADVANCE!
ADRIAN. >_<
HI THERE,
ADRIAN. >_<
please look at this and tell me that these are the parts you need. i will supply you with part numbers if they are.post-14067-1186364698_thumb.jpg
i haven't been able to find the gearbox mounts. i do know that you can get the nismo 1s from justjap. Gearbox mounts
maybe arbess will be able to find the genuine 1s for you.
1990 R32 GTS4
drivers side propella shaft rubber boot (shaft to front diff housing)
Picture added to help clarify the part:
im not sure what part your after. i dont know of any rubber boots like that on the front driveshaft. steering rack maybe?
Yep, those are the two gaskets i'm chasing which you have highlighted in green would there be any chance you could get the part numbers for these that i have to go to Nissan with to order them direct - i was also going to chance the half moons whilst i was in there replacing the rocker gaskets - so the parts i'm chasing are:
1 x 13270
1 x 13270 + A
2 x 11051H
I'll also grab that gearbox mount from justjap so thankyou very much for the link to that page, it's greatly appreciated!
Many Thanks,
Adrian aka skysaresilver
1 x 13270
1 x 13270 + A
2 x 11051H
Many Thanks,
1 x 13270 = 13270-58S01-
1 x 13270 + A = 13270-58S11-
2 x 11051H = 11051-58S00-
>_<
hey mate
just after part numbers for R32 gtst 93
idler pulley
tensioner pulley
water pump
timing belt
are these part numbers the same as a r33 cause i've heard they are the same
thanx
21010-70T25 - RB20DET water pump (or try 21010-42L25)
13028-20P25 - RB20DET timing belt
13074-58S00 - RB20DET idler pulley
13070-53L00 - RB20DET tensioner pulley (or try 13070-73L00)
Water pump is approx $110 retail from Nissan
You are better off getting some Gates or CBC bearings/pulleys as OEM you can expect to pay $250+ for each
Autobarn for eg, can order in a kit for you fairly cheap and it also includes the oil seals, but CBC bearings are better quality and a little more expensive (still cheaper than Nissan though)
Also the Gates Racing timing belts are about the same price as a standard OEM belt
Are you doing the 100k service?
you are a legend :P
I'm trying to find a noise and had to take my balancer off in the process so i thought I might aswell do it again. maybe if i'm lucky it will get rid of the noise too.
nah not going to nissan. bearing industries couldn't find the part number for rb20's.
thanx heaps :thanks:
thanks mate for the info.. :D
No probs. ;)
need part number for a o2 sensor for a '95 model series 2 rb25det?
R33 RB25DET 02 sensor part numbers:
08/1993 - 11/1993 number : 22690-21U00 (alt number 22690-83T10)
11/1993 - 01/1996 number : 22690-83T10
01/1996 - 11/1997 number : 22690-83T10 (same)
11/1997 - number : 22690-83T11
Edited by FighterJoe
Excellent thread! :D
I need some help also for the following:
1996 R33 GTR
BCNR33-024671
Injector sealing O-rings
Intake Plenum Gasket
AAC Valve Gasket (maybe the same as this? 23785-40F00)
Driver Door Seal
Passenger Door Seal
And finally... the little GTR Square plug that goes by the coin holder on the center console behind the shifter boot.
Thanks in advance. ;)
David.
1996 R33 GTR
BCNR33-024671
Driver Door Seal
Passenger Door Seal
David.
For BCNR33-024671 (Nov 1996)
Injector sealing O-rings - Insulator-injector number: 16636-V5000
Intake Plenum Gasket - Intake manifold gasket number: 14035-05U10 (assuming intake manifold gasket not throttle chamber gasket which is 16175-05U70)
AAC Valve Gasket (maybe the same as this? 23785-40F00) - AAC gasket number: 23785-40F00 (yep same as the one you quoted)
Driver Door Seal - Right hand door weather strip number: 80830-22U00
Passenger Door Seal - Left hand door weather strip number: 80831-22U00
the little GTR Square plug that goes by the coin holder on the center console behind the shifter boot - Switch hole mask number: 68960-24U00
Hey just me again,
Thanks once again for the part no's you were able to get for me last week they were tops and i ordered and fitted the parts from Nissan on the weekend!
Just another quick question for the Injector Sealing O-rings are they the same part on the r33 gtr as on the r32 gtr, (16636-V5000) or another no altogether, and are they the seal between the fuel rail and the injector head? As that's the part i'm after!
Many Thanks once again,
All your help here with Part #'s is excellent!
skysaresilver
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
