i am fairly sure you would already know this considering you are useing the nissan part finder system to get all of these numbers (figures that out be seeing the pic of the rear QTR glass window). but all of the numbers that start AY are pitwork part numbers. unless they know what they are doing some dealers can not use theat number in their system but if they know wat they are doing they can cross referance to a genuine nissan number.
i should post a pic of my certificate saying im qualified in using nissans fast catelog :whoops:
never said you where not qualified at using the fast system. i am to. just saying that some dealers can not use the pitwork part number in their pricing system. just to make that clear
Anyone got the part number(s) for the gasket/seals for the cam covers in an R33GTS-t? Want to paint my cam covers and while I'm at it I might as well replace the seals as there's a tiny leak
Sorry guys, its been a long weekend. Crispyfries, mate if i were you i would call up Nissan and ask them if the bearings can be interchanged and which bearings are the cheapest.
Cheers Ron, I've actually got my hands on a set of R33 hubs now anyway, and what I had in mind is definitely not possible, even if it was the same bearings.
Just a quick note to everyone, my Windows has died and i cant be stuffed tracking down a copy of windows and then reinstalling it. Linux is working just fine for me. The only thing is I havn't got Wine (Windows emulator) installed yet so i can't install FAST. Sorry guys. Although there is at least 2 people that read this thread that are certified in using FAST (Thats if I assume right) Maybe they could throw some numbers in for a while.
Cheers, Ron
R32 GTST Manual Flywheel Bolts: 12315-04U00
R32 GTST Manual Bellhousing Bolts: 08071-0601A
R33 RB25DET Rocker Cover Gasket LH: 13270-58S01
R33 RB25DET Rocker Cover Gaskets RH: 13270-58S11
R33 RB25DET Cam Half Moon Seals x2: 11051-58S00
IM searching for a set of Brake shims for GTR33 Brembo front calipers? they are also the same calipers as the R32 GTR Vspec brembos
first picture is of the brake system on R32 GT-R and the second is of a R33 GT-R only the R32 has shims. part NO. 41218 12U26
Edited by neofenrir34
for the fly wheel bolts i also got Part No. 12315 80S00 if it fall's between 0589 to 0789 production date
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
