  • 4 weeks later...
Hey guys, got a r34 gtt .. intercooler hose part number 14463 AA501
i have been sent from the wrecker the same kind of hose, but i have been having problems fitting it.
Is it possible to see the location of the 34 one and conpare it to the location and part number on the 33, because the hose i have been sent is for a 33 not a 34.
cheers Mick
  • 1 month later...
  • 2 months later...
hey i'm after the part number for the fuel sender/cap that goes in to fuel tank in the boot that has the fuel feed and return lines into it
the white thing in this picture http://i.imgur.com/RKwLA.jpg
thanks
  • 5 months later...
  • 1 month later...
  • 3 weeks later...
Local Smash repairer should have a variety of screw in rubber bonnet stops. One of them will look oem and fit.
Hell he'll probably give you a couple. Worked for me :)
are the ones your after like this ?
Thanks Richard
Really appreciate the offer.. your a champion
and thanks Ben for the part number i found it on ebay $15 for 2 delivered has the same part no. but says its for a navara im assuming its all the same
cheers Jayson
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
