The cage would need to be made from cold drawn seamless steel or crome moly. If it requires cams approval it will also need to be welded by a certified welder and designed around cams specificationd. The bends in cages are not actually done with a mandrell bender as there is no way to phisically run the dye through the pipe when the length is so long they are actually cold bent useing a good quality hydralik bender so as not to stretch the tube to much I will post some pics of my cage in my R33GTR in the next few days.
since when did it need to be welded by a certified welder? have the rules changed recently?
I made our roll cage in our race car and its cams approved....Coincidental i happen to be a fabricator by trade so i guess that makes me approved to weld, but at the time i wasnt aware it had to be welded by a certified welder....strange the chief cams scrutineer never mentioned that. I guess the rules have changed over the last few years.
But yeh...CDS which i think had a grade of 350 or higher and chromemoly are the only properly approved materials to fabricate your cages from at least for cams spec anyway.
We have a electric over hydraulic bender, right die for it and no worries with bending the tube cold.
You dont have to be a qualified welder, but it helps. Otherwise the cage may not pass the visual inspection. Plus, if it was my cage, i would want to know that the welding is in conjunction with an approved weld procedure that has undergone tensile testing, radiography etc etc
If you try to use chrome moly for your cage and want to get it approved and log booked then you are up for some expensive engineering. So whilst the material itself is approved, any cage with chrome moly needs the engineerign carried out as you are no longer using the recommended diameters and wall thickness as per the FIA/CAMS guidelines
I havent checked the latest cams book, but surely they would list what diameter pipe and wall thickness the chromemoly would need to be that would comply. Yeh there is alot more fuss when welding chromemoly then just straight mild obviously. Needs to be preheated to the right temp and then tig welded and then probably some post heat so it doesnt cool too fast so it doesn't lose its tensile strength.
like harry said the full manual is online now, they send out the small versions with a couple of sections to NC and PC now as well as L2S.
its not really free though....they left the license fee the same but don't provide the book any more....nice one CAMS.
there's nothing like having a open a computer when you need to quickly check something at the track :D
  • 1 year later...
Are you trying to sell cages?
This is the second old roll cage thread you have dug up.
Edited by W0rp3D
W0rp3d - FYI, there are only two rollcage threads in the fabrication forums wtih different info. I have supplied more or updated information to assist others in their roll cage building instead of starting my own thread asking similar questions.
I have no plans to sell cages. I would like to build my own cage for my R32 and hopefully get it CAMS approved if not go to a CAMS workshop to get a cage installed.
  • 9 months later...
does any1 no how to bend pipes proply without a pipe bender for a role cage
you need a mandrel bender - home roll cages arent reall the go - get one made up and weld it yourself is better than trying to make one from scratch without the right equipment.
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 8th February 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Thursday 6th February 8th Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. email [email protected] To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and it is reccommended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs on the enty link. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
    • Just yesterday the car started to shake a bit when idle. So tomorrow ima test the some wires and packs with the multimeter and see what it is. Hopefully is a pack because thats the easiest thing to buy same day here where I live in the USA.
    • shot myself in the leg and now last night I have shaking when I idle lol
    • I'm not a big fan of the Cometic gaskets either, as above the head and deck need to be like a mirror (can't remember the RA) so Kamieri sounds like a good idea.  FWIW a mate of mine hordes old motor stuff and has some blank unground Nizmo cams for one of these in his supply if random shit if you're interested.
