Hey People,
You may have seen the odd post about these from time to time or even ones which I have sold previously. Basically these Light Up Skyline Garnishes can be wired up with ease to work with brake lights or constantly switched on with your parkers, and should hopefully be available in various colours and look much brighter than the factory unit, as you can see.
The total price of these Garnishes will be around $300, less without the supply of the lighting. I am also may be getting some to have a 'stealth' appearance during the day when turned off, (no clear looking letters as you can see with the silver one thats not lite up) this element of stealth may come at a small additional cost.
So if you have been wondering where to score one or have tried making one of these trick pieces for the back of your liner, wonder no more! If you genuinely you would like one of these please post here (no chit chat please) with the colour and model of your car (R33 Series 1 or 2) and I will be sure to get back to you very soon.
The colour of lighting is only limited by your imagination so ponder away! Although most popular is the red and white lights (note that the grey one with red lights is still in primer/undercoat and not finished).
Thanks.
  • Replies 113
how easy are they to install, mine doesnt look to easy to remove/replace
It is a very simple installation, you just need to remove the plastic boot trim/panel from the inside of your boot then its 4 nuts and your out!
I will write a tutorial on installing them once they some are sent out
hey i have 2 of those garnishes if you wana buy off me to make em lol i dont evn use it coz got my original one back on so other 2 are just spares sitting there looking pretty.
sorry mate, on closer inspection i can see how easy it is to do
i will contact you in a couple of weeks when i have some spare cash
Hi mate what is used to make them light up leds etc????
Also what do you do for the S1 panels as they are not colour coded to match the paint?
Led's are used. and they are painted to match the body color mate :thumbsup:
Thats right! The colour is matched exactly using the paint code for your cars colour.
The finished product looks almost identical to the factory body coloured series II garnish. Obviousy the series II has the difference of the concave shape though.
Is white a legal colour for lights on the rear of the car? How much extra would red be or is it just an optional extra for same price.
Also when will you be making these, very keen on one :)
Also when will you be making these, very keen on one ;)
Everyone I have spoken to that does rego inpections etc. and knows about that kind of thing has said that there are no issues with haveing i white. I have had cops pull up behind me various times and they have never pulled me over, let alone say anything about it, as it looks like a factory nissan job.
Although Red obviously carries zero risk for the concerned driver. At this point I'm estimating the red light up panels will be worth a little more than the standard white which I already have.
Will these fit a white 95 R33 GTR?
If so count me in.
Pretty sure they would. I don't think there's any difference in the garnish between GTR's and GTS-T's. I've seen these things in person and they look fantastic! Better than the factory ones you can get which light up green. Hope you haven't forgotten my order Nick ;)
White is illegal as only white light is allowed to be emitted from the front of your car constantly. Reason being is people will get confused and think you are stuck in reverse. Anyhow, same applies for the front with red light.
Are you going to post some examples of the ones you are working on? I need to see some before I go ahead. :thumbsup:
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
