  • Replies 53
Haha, cuddle chair
Dave (Nytsky), I've got an ecv. It does bring the noise down a lot, but what I was saying was its just the car itself that brings the attention. People have been defected even for not loud aftermarket exhausts (not really defective at all)
Get another couple of doors. Works for me. :P
I've been pulled over thrice. First time cos the copper just wanted to have a look cos he couldn't work out what it was (R34 4 door 3.5 years ago was a rare thing), second time I chirped 2nd gear so fair enough but he didn't book me, third time one decided that accelarating quickly from servo to 110km/h for the freeway was not allowed. No ticket but it does show that they are attracted to the noise. My car is quiet but at redline to a casual observer it just seems to them that you must have been speeding. I mean how often has some random citizen motioned to you to slow down just cos you are doing 50 in 2nd gear? It's all about perceptions.
.....every time I drive through a construction zone. And my car is relatively quiet.
I have a fair few mods (usual stuff), but the main stuff that is apparent would be the exhaust (3.25" straight pipe with no mufflers and the pod filter). My exhaust is quite loud because of the turbo, but I like it as loud as possible
lol you think thats loud. i run a pipe from turbo.. well still got cat.. but straight thru pipe.. Friends tell me its freaking loud.. but im just use it now.. hahah
Where did you get your evc from? also how much!!
Edit: Noticed you wrote straight thru pipe with no mufflers.. So i mis-read it.. Ok yours is loud as well.. But how cool does it sound eh lol??
Edited by siddr20
Been pulled over a few times.. been let off for everything they have trried to imply. Have had a 5l commodore, a Gen III & now R32... all noise makers..all on my p's.
No B.S = generally no fine unless you were caught doing something stupid.
some cops are nasty some are nice. being on your p's makes a huge difference. since being on my blacks i haven't been pulled over once.
My car is quiet off boost. real quiet. 3.5" turbo back but with a cat, hotdog and rear muff. only when boost peaks and the screamer lets go its a different story. i like that better it scares the shit out of people but you can still drive around without being noticed.
also keep your car dirty. thats a good tip.
i love all the attention skyines get. people hate you for it and dick heads love you for it and you can tell them all to snort piss. i only drive mine because its the best bang my buck buys.
dont know if that makes a lot of sense, i'm a little ill and a little out of it on medication
Edited by Black Betty
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
