Winton Sprints - Sat 28 July - Club C/ships Rnd 5
Well the weather was great, my car had a lot of work done to it last week and was ready to do some really decent times, I should've been able to do a 1:40 flat because last time I did a 142.
I didn't even get to do 1 flying lap because my car broke :santa:. Unfortunately the car only worked for Adam's first four laps and he got a silly 139 in it, very disapointed that I didn't get to have a good run... Next time!
Jack you are absolutely crazy, so smooth, thanks for the ride in your car!
  • Replies 105
Posted Images
No mate, I spoke to him though.
He looked like he knew what he was doing.
I think Adrian was his name. I got his business card which has a link to all his photos.
He said that photos of our event should be up in the coming week.
I will post up his details shortly so all can see. :D
Great shots! :santa: Were you the guy pointing the massive camera lens at cars coming through the S bend?
Here are a couple of laps of the Group 1 super sprint from my car: http://www.gtauto.com.au/movies/WintonSS.wmv 29mb.
Nice work Wayne!!!
Looks like your car is very sorted suspension wise, handles very well and no major under/oversteer.
I guess with that turbo its very responsive and doesn't come on boost hard trying to throw the car off the track...
What happened to Matt?? Did something go wrong??
Jack - Open wheeling diff & sh!t suspension.. I couldn't get power down, car didn't ride flat thru the corners, too much roll..
Well done Wayne, all that go-karting experience gives you great driving skills. See you at Sandown :thumbsup:
Matt...like i said, even with the slightly soft suspension and open wheeling diff. There is still time in your car if you have of just got out there and kept lapping. I bet if you had of continued driving you woudl have bagged a 1:39 (SERIOSULY)!
I did get 1:39.9 >_< There is alot more time in my car with the right setup (and more driver skill :thumbsup:) I know what you're saying but I wasn't happy with the suspension setup, and would be just burning rubber and fuel. Always next time.
Yeh, i was just frustrated that i wasnt able to get my car there. I woudl have seriously paid your entry just to do a few laps in your car :thumbsup:
Instead the only sport i got on the weekend was darts and drinking beer...oh and some pin ball >_<
HAHA, Darts was one of the highlights of my weekend, I've never laughed so much!! The Brisby quick draw dart technique... Nice! And our great selection of tunes, go the oldies.... :) And the pinball machine that was about to give someone the electric shock of their life because of the faulty wiring...
I wish we had video footage of Newton stabbing the dart into Mav's leg...
Do I get a prize for dirtiest car? I stole the title from Chris :)
Had an awesome time though! So happy with my car >_< pitty I suck at the driving it part :thumbsup: ah well more practise! Thanks heaps as well Chris for all the help!
I will post up his details shortly so all can see. ;)
Would you be able to post up the web address for this guys site?
Interested to see what other events hes been shooting at.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
