i'd probably manually form the 6" pipe part - as its probably difficult/expensive to buy (especially that small quantity) - Cheers for the info though :D
Did you powdercoat or paint the black pieces - fuel rail, cas bracket, inlet cam gear, strut brace mounts?
Fair enough. My mechanic's shop is next to to a engineering shop and we used one of the off cuts :).
Some black pieces are powder coated, others are painted. Basically anything that had parts that could melt were painted; this includes the cam cover, CAS, inlet cam gear, etc. Parts like the strut brace brackets, power steering reservoir, fuel rail, oil cooler mounts, and all other brackets, etc were powder coated.
All the charcoal colour items are powder coated as well as the red cam covers.
I painted all the cam gears etc, but the clear cam cover, purchased from PSI Parts, didn't fit and fouled on the inlet VCT bolts. He tried to claim my cam cover backing plate sat 3mm further back than normal; funny how the standard cover has no issues with fitment and clearances. >_<
I did not claim that at all, I even personally fitted your cover on a standard RB25 which had no fitment issues. Disagreeance aside, we have just finished another batch that have had a few minor modifications (one of which was to make the VCT bulge slightly larger to allow for NEO engines).
Mine fitted perfect on the rb25det >_<
Dale PM sent, prefer to discuss in private, but i stand by what i wrote.
MintR33: Pretty much. I know we had to gently bend one of the tubes, coming out of the reservoir, but that was more to do with clearing the turbo. The lines did reach without modification, but obviously do not sit in the natural position, but this was fine as the lines are still not kinked.
  • 1 month later...
I took a quick photo tonight of my engine bay, I had the plenum, crossover pipe and rocker covers polishes, then I chromed the injector caps and rail as well as the timing belt cover. Add a few silicone hoses and its starting to look better.
Only problem with this process is the more you do, the more you see can also be done. I’ll start on the left hand side of the engine next.
Hi 4door sleeper,
Could you tell me if the Greddy Washer bottle uses both front and rear washer motors? and does it bolt in as per the standard unit?
Yes the bottle has spots for 2 motors (had to use my old ones as it didnt come with new ones)
It mounts (slides down) onto a bracket they provide, not sure if they used exosting bolt holes or had to drill them.
Since I couldnt edit my earlier post, here is another picture of my engine bay from the other side
Edited by 4door_Sleeper
Excellent, if what you're saying is that it's a bolt in replacement thats what I need for my GReddy plenum
I guess it depends on your piping setup. As the 'GTR' style piping allows the washer bottle to stay in it's current location. Other people have relocated the washer bottle to underneath the guard. The other option might be a catch tank and washer bottle setup in one, similar to that of the RIPS version in NZ.
I have since spoken to Dale from PSI Parts and he has kindly agreed to exchange my cam cover, once i have the time to send the original one back to him.
I have since removed my frustrated post as i now realise PSI Parts are an honest business.
Dale i know it has been a while since we last spoke, but i haven't as yet had the time to post the cover, sorry it took me so long to find where i had posted my comments.
No worries mate. Whenever you're ready :)
Hope the car is past it's run in stage so you can start to enjoy it.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
