Looks like a nice pick up. Glad to see even though you went to the darkside, you picked the right car :P
Yeah, it's always annoyed me that Toyota don't make an affordable small-midsized RWD car.
The last small car was the AE86 and we all know the stigma attached to those cars, plus for a basic mid 80's car they are sickeningly over priced. After that the next step is an IS200 which isn't cheap and the aussie ones have junk engines. Toyota also don't do any RWD 4cyl turbo engines either so you have to convert stuff to get what you want. Bloody bean counters....
It's a shame really, as I think Toyota would have done a good job at it, but they let that segment of the market go.
Oh well, I'm glad that Nissan didn't! I think I'll always have a hankering for an AE86 though...
Yes, it has a mildly worked Clevo in it, the whole drive train (except diff) come out of our old XD Ute we used to race.
It hasn't been out of 'the box' for too long, so there is still some fine tuing to do, but it is doing 1:45's at Winton.
Still pretty much a basic Falcon underneath, just beefed up suspension - thanks to my good friends at Pedders in Bendigo, brakes are slotted rotors (standard size and standard callipers), with Bendix Ultimate pads.
One of my favourite pictures. The guys at RPM Photography were in the right spot with the finger on the button for this one lol. Kudos to them for this, as it's by far the shot of the year at QR for me.
great shot! but coming second whats going on! ?? haha
:P Smarty... I had wastegate problems so I missed race 1 and had to start from the back in race 2.
I could ask why it is that you only just managed to get under 60sec on the Clubman yesterday at QR too :O
i have a plethora of excuses !! which one would you like to hear! lol
i thought youd like that!:no:
Well, I think maybe it's age catching up?
Semi-slick 285 hoosiers leave nice lines hey lol
is that r33racer in front?
It's his father driving it actually. Michael didn't drive it much last year.
Thats an interesting shot, where was it taken?
It was at the old Morwell Hillclimb circuit here in Vic. It's closed down now, but was a lot of fun. It's just a pity you couldn't get any heat into the tyres before a run.
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
