Roy, you know you're welcome to come and skid mine anytime up here! Sunday 21st of this month... get a flight, come drive Lakeside.
I beleive I can Savman. And Rex is super quick! I reckon I'll be right in the rain, but if it's dry, that thing has some serious pace! 380hp and about 1100kg will do that :)
Edited by Marlin
I have just the thing for your car to make that power. Internals are free, that is all i keep hearing from Tarmac rally guys :rofl:
yes troy, internals are only free if you're losing dumby. if you're winning almost nothing on your car will be not under protest...
BTW, is it just the pics or the wheel nut to wheel fitment a bit howsitgoing? could be worth getting some different nuts that fit the taper of the wheels holes a bit better. :)
car looks sweet as, and nice choice of seat... (yes I run the same :) )
Yes Troy, as I've discussed with you elsewhere about the cheating phenomenon, it's just not my style. I'd rather wax the Porshes in a true sh*tter :)
The wheel nuts are fine, it's just the picture, no interference there as all. I'm saving for a set of RAYS nuts though.... I couldn't even find any all the same colour! :)
The seats are the best ever... it came with them and I was stoked. Having used them for the last two Targas, spending six solid days in them, I know that are simply the most comfortable and supportive seat I've ever tried.
Thanks for your nice comments too :)
Thanks Chris :dry:
Very easy to do, just rivetted to the original.
I find it help in situations where for whatever reason you may get a long brake pedal, there's far less chance of going for a heel/toe and getting under the accel pedal.
I had that problem a couple times at wakie last weekend, braked too deep and my foot couldnt hit the gas properly while changing!
Thanks for that!
Cheers!
  • 1 month later...
MPC used to look after my car when I kept it in Melbourne. I saw a few cars there they look after that had flocked dashs. Maybe they're the flocking experts? I'll give the boys a bell and see where you can get a good flocking.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
