hi
my race car toy (yes a girls car) but catch it if you can!!!!
260kw 850kg power to weight 3.2
dave
ps the other car is the bsm gtr :P
Aww that car is so cute!!!
It made me giggle last time I seen you out at OP...Awesome!!
Just got it home, havent even taken it off the trailer (neighbour is coming over after dinner to help) and im already posting pictures :)
YAY!!!It's Finally here!! :/ Well Done :blink:
Go Ben!
Yup took 5mths longer than it should have because of the dollar crashing which caused a lot of headaches, long story short is instead of importing a brand new kit in pieces from usa (where they are made) i've bought there shop/demo car which is 100% turn key ready to race (well, if I could fit my fat ass into there sparco seat lol). Another bloke in Perth bought the other shop/demo car and that is all that is in the country and its likely to stay that way for awhile unless you want to spend $40k to buy 1.
Because of that its got the same engine used in the actual Aussie Racing Cars which is a 1200cc 125hp 5sp Yamaha motorbike engine. Yup a lot less power than the Hayabusa engine ive had sitting in the garage for the past 4mths but atleast this car is ready to go and if I need more power I can always do an engine swap next year after i've learnt how to steer it.
It weighs approx 540kg so it's not super light like a Radical or the Aussie Race Cars but its no 1500kg gtr, has a 1 piece fibreglass shell with removable engine/boot covers. Entry is via the hatch on the roof (like the american nascars have) has a normal pedal box, adjustable bias, autometer gauges, VL Turbo front calipers, VZ rear calipers with rotors from a Mustang, EBC pads and a fuel cell in the rear.
cool car ben! glad to see you got something finally. it is a shame they let you down so badly though. :D but hey, you've got 'a' car now so hop in and enjoy. take it up to maccas for some drive through I say....
(on the trailer of course...).
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
