Thanks all! I can't take credit though, my mechanic Sam made it all up and did a great job of it.
Richard, I ended up having the box made up by a friend of 'Craved' on here. Sam ( www.drdrift.com.au ) did all the other work with the hard lines etc
Mate, I would have loved to have had it bought off the shelf, would have saved some headaches! It was all custom built.
I think there may be a market for a pre-fabbed CAMS approved kit like that though
marlin - you need to mate, both the shitters are keeping a knock off 400r and your rival 32 gtst company at the moment!
roy - for tarmac and circuit events the e2 and 3 boxes aren't too bad unless you're dragging. there are a number of beefing up options too that wouldn't break the bank. apparently the boxes get a bad name from guys doing engine swaps into local cars and having the weak local gsr 'box fitted up.
the 4g63 engines go forever, much like sr20s and rb20s etc. for the 4g63 there are plenty of cost effective 2.2 and 2.4 kits too... when i priced a 2.4 rebuild a while back it was only $170 extra to got 2.4 over 2.0 using a factory crank (assuming you'd replace the standard crank).
the pre-e4 diffs in gsr and rs are strong enough for just anything (unlike evo 4 onwards ayc (gsr) units). the gsr spec e1-e3 use an open front centre and are best to be swapped over to ralliart helical front centre found in the rs.
if you wana prepped one i'm considering options on this one and happy to set it up to a spec requested... wont be after big dollars for it either.
boz22n - nup, csc/bmax are grooved that way, zoom in on the veins
there are a few manufacturers doing this, i got confused when fitting mine also, but definately run that way.
Ben are those rotors on back to front or and i looking at it wrong?
The car looks sweet Chris.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
