Well here's my latest project. All the machining is finished at last and im just waiting on a couple more parts. Its a stroked 3.1lt open deck engine. The goal is a massively wide torque band and around 450awkw with a pair of GTRS's.
If it didnt have sunroof that thing would be perfect balls to the wall track car. Even as is, when i am back baby i have time off so we are going to have to have a showdown at Wakefield. It has been 6 years since i have driven that place
Whats bad about a sunroof roy? Im making a carbon "plug" for mine soon, party to save weight but mostly for headroom
Looking good Baron! And the Tomei is a better choice anyway mate, should help to keep strut towes in one piece. I had a nice fat Nismo one on there prior to buying mine which was a shame to see go, but it was for the best.
I want to try to get to Oran Park prior to it's closing, you should bring the S13 out and we can have some fun :)
agreed. as you know I very nearly didn't buy it when I found out it had a sunroof. in all the pics I'd seen I didn't see the sunroof. after my 32 GTST with sunroof I'd promised myself never again, but the car had all the right gear for the right price so I compromised again. :)
and yeah mate wakefield is a go. showdown will be good. in fact the little silvia might do well there. your thing will be pretty wild around wakefield and the silvia has just the right amount of torque. it'll be interesting to see which one you can drive around there quicker. actually yours will be quicker. it has so much good gear now. the titanium exhaust is worth 3 or 4 seconds at least....hehe.
Phunky: definitely try and get to oran before it closes. if you can't get your car up here mate we could probably even share mine for a day. you don't want to miss driving it before it closes. it's a fun track.
GTs30t: sunroofs are bad for track car. less headroom, plus more weight from the sunroof and the extra bracing they add under the roof. plus of course if you roll there is a chance of something penetrating that space. but mostly the biggest killer is the headroom or lack thereof. One day I'll probably just get it removed and get the hole welded up. I would have never bought another sunroof track car but this particular one had all the right bits so I caved. :)
very nice mate. what are you doing to that poor virginal car! :) it should be one hell of a beast with 3.1L and those two massive turbos! I'm sure you've told me before but what plans for the head?
If you throw a big enough solenoid and ram on it i am sure you can get the sunroof to drive open in a split second when diving on the brakes so you get a Veyron/Mclaren F1 style air brake. :)
:). haha. that sounds way to fancy. we just get 2 barn door hinges and attach to front of sunroof. then as I approach each corner, reach around down shift, then punch it up with my fist and hold till turn in. just like a veyron... only better.
DO please post up when you guys are going....might have to coincidently be there in the 33 :)
Looks good Ian. Just a quick question, do the tops of the sleeves where they stick out of the block have flats on them to retain a better wall thickness?
Mike
Looking good Dave. Is that a 3071?
Ando: That would be awesome to compare setups and get a feel for how each mod has affected each car. Should definitely organise something. Matt (Boxheadmr) asked me to come to an NSCC day at Wakefield on the 8th November, which would be good, but want to make sure I get OP in there if I'm making the trip.
Hmmmm S13 convention @ Wakefield or OP! Keep me posted :(
Really keen to get a whole bunch of serious S13's and drivers together to compare notes!
lol, I am a long way from serious driver or serious S13! :rofl:
and yes badhairdave can come too. all this large turbo is giving me turbo envy... now thinking mine is too small... looks like you should have a great set-up there.
S13 convention? Will be interesting to see how the old R32 goes with similarily powered 2L S13s. Be a fun day playing with cars all within 2-3 seconds of one another....rather then the usual Vic days where i am chasing all the Racepace GTRs who are 4-5 seconds quicker with me being the clearly slowest :( LOL, that is assuming i am not the slowest of all the 2L cars which could be the case around bumpy old Wakefield :rofl:
I'm massively jealous of tis turbo setup, an seeing as my manifold just cracked I'm so tempted by it!
Full Race Twin scroll, twin external wastegate manifold
Twin scroll 3071R
Twin Tial 'gates
Full Race dump pipe
Who wants to sponsor a starving 180SX driver?? :(
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
