Pity they're a cast iron boat anchor Al!! :)
Just jokes, I am jealous of your RB25/30 power outputs but not the extra weight involved... but you have 160rwkw's more than me at 100km/h... that's depressing ;)
Try Winton out in October mate, hopefully we'll get some decent weather.
Ben: lol :D
That was more of a "dig" at Bris :)
I also wouldn't fark the balance of a 180, by fitting an rb into it.
When flat footed, in 3rd, things get "interesting" at about 80km/h.
October hey.... Any threads up yet? What type of track day is it?
We all know that an rb30 conversion is where it's at! :P
Slap on a 550hp Garrett and you have 320+rwkw with better response than a std/factory rb25 setup :P
I am tempted to take mine to the next Winton track day, whenever that is, have been giving some serious consideration :bunny:
Below is an older power curve. My car now makes 330.6rwkw with even better response and more torque; as we have since adjusted the cam gears and done a retune
I will post it again. RB30s are for people who rather roofies then romance and who think handjobs off hookers isnt include as paying for sex
May be time for a used OS Giken SR20 gearset. I have been on the lookout. If i find some i will let you know.
Blolody VLs and Silvias eating up the supply of engines and gearboxes...also the bloddy R31 GXE crowd :(
LOL, there,
Do NA R33 boxes fit and share the same ratios?
Blolody VLs and Silvias eating up the supply of engines and gearboxes...also the bloddy R31 GXE crowd :)
LOL, there,
That sounds easy to find mate... lol
Interestingly, popped over to my race car building mate over the road yesterday, he has a partially busted 6 speed HKS GTR gearbox there. The transfer has been cut off it for RWD. It's not a getrag, its an early box.... I'd nearly forgotten HKS did thissetup, they did didn't they? lol
Anyone know where to source the bits to fix it, who made the stuff? it's wierd, it has oval dogs instead of Aussie style back-ground dogs.
well an update for my silvia.
I'm taking some time off in the next couple of weeks to sort out a few little things on it.
install some cams. going to go with greddy easy cam, 256 in 264 ex 10.5mm lift on both
install exhaust tip extension. yes it sounds gay but currently exhaust doesn't extend past the uras bar and it's getting destroyed (fatz give me back my tip you carnt)
get air con re-gassed. NEED AC!
get diff backlash set properly (diff whine is annoying)
raise height (yes it looks awesome low but the trust PEII exhaust is getting destroyed and I think it will handle better with some suspension travel)
install some new seats, either 32 GTR or 34 GTR for street duty, will keep current race seat for track use
install the Trust intercooler kit and piping I've had sitting around for it for ages.
may swap out the walbro fuel pump for a nismo or sard (it seems ok, but I just have no faith in them, it would not have been my choice)
may need to upgrade the nismo 555cc injectors to some blitz 850cc ones. especially if I go for an E85 tune.
may swap out the HSD coil-overs for either some buddy club racing spec dampers or some cusco zero 2s. both are quite good.
then get it tuned to about 22 or 23psi with the cams and new intercooler and piping hoping it will crack out a fat 250rwkw on pump 98. and if I'm keen I may get an E85 tune and go for 270 or 280.
BIG LIST! but it's going to be so cool when finished. oh, and will get the front bumper repaired from where troy farked it... lol.
Was thinking that the ride height is nice and low...i know i run mine higher and it looks gay for it. I am not fast so have to remember to look and sound it ;)
I have another date with a Caterham, this time an R300 race car. I wonder if the magic has worn off or after driving it i am still going to be hungry for one?
Sorry I'm late guys, but I measured those ride heights for you.... centre of wheel to gaurd.
Front - 322mm
Rear - 332mm
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
