nice GTST. I have to say that navigators foot rest is a work of art! can I ask who made that or where did you get it from? it's almost too good to rest a shoe on....almost. ;)
thanks for the comments guys.
I got the foot rest off good old ebay, they are to suite escorts and just had to cut the bottom part to suite the floor pan where the indent for the cat is.
http://cgi.ebay.com.au/Rally-Race-Car-Co-D...=item2c5209ea6d
Edited by trezy85
All the good R32 GTSts have been punted in the rear righ quarter, especially the good silver ones...
Must be a common thing with silver 32s as i was lucky too :P
Go the dirty2 GTSTs :)
yep. mine copped one :( It was half silver at the end of it's life.
My Rally Car.
Its the 2nd car ive built for the Amsag southern cross rally series. Its a 1993 S13 Silvia with SR20DET.
Like the Silvia, but boy some of those roads are straight! Noticed in the photo's you are running A symetrical 4WD tyres on the front. I found the best improvement on my turn in was going to a narrower 185 steering tyre, that is a different pattern. Works very well in the thick graval also.
How do you find the turbo boost on the gravel. There are a couple of guys out here running various RWD turbo's and they really struggle in the twisties, I seem to have it all over them.
Had a minor mishap the other week too.... 140km/h backwards.
Just a roadbook on that sprint. I knew the corner was there, just had brain fade playing with the jammed wipers.
Got a bit of whiplash and other than the body work, a bent lower suspension arm. Love how strong these cars are!
Yeh they were, it was definitly a different event to what im used to. Yeh for that event only they were just second hand tires i got from a mate, i now run 195 BF Goodrich all round and am very happy with them.
Yes Turbo boost can be very explosive since it makes peak torque at around 4500rpm but with the external gate fitted now so that boost is consistent i am finding it not too hard to control you just have to stop yourself from planting the right foot too hard which is quite hard when your previous car is a 1.5litre Datsun lol
The car is still very new to me but it is already showing some very impressive stage times, at the moment we are fitting Murray coote suspension all round i will post pics when they arrive which should be in the next 2 weeks, it was an expensive upgrade but should definitely be worth it.
Glad to hear the car didnt have too much damage after the hit, was it too much rear brake bias that contributed too that spin? or was it the fact you were too wide and on the loose stuff? it seemed to snap soo quickly
We have been playing with bump steer adj over the last little while. Typical me, "can't be that hard to make". MkI was pretty basic and worked well...... until there was a big excursion at speed hitting the back of a ripple strip at an odd angle. Result below.
So then the thinking was we would try a commercially available option. Just Jap sent these ones that were cool but way to short. My brain did its usual trick and put me infront of the lathe again, And this is what came out after 2 0r 3 nights of toil and frustration. 9Mine left, JJ right)
And fitted in the pig. I'm slightly ashamed to admit, Its a Toyota. With all Nissan underpinnings!!!!
Cool, sounds good. It's the same with the Skyline over here, very pleased with the results, consistantly in the top 3 in class and usually top rear wheel drive. Bloody FWD cars are so quick (dull) these days.
The loose was mainly brain fade, but we also have this stuff called mud over here :( and the car just aquaplaned on it.
The first run there was more grip because the mud haddn't come through yet. The corner caught out about half a dozen cars that day.
The loose was mainly brain fade, but we also have this stuff called mud over here :D and the car just aquaplaned on it.
Couldnt agree more about the dull comment haha, but we dont seem to have many FWD guys running in the events i do anyway.
Yeh mud makes any corner exciting when its bad like that, my last event was very similar i was a passenger most of the time thank goodness for some ruts that saved me several times from an off. The 4wd guys killed us on that event unfortunately. I have some in car of that but still have not put it up onto youtube as the files are too big. You get the idea off how bad it was from the photos though lol.
Progress!
Block and pressure tested
Shot peened and re-sized rods
Block decked
Honed cam tunnels
Clearance ground crank
Rotating assembly balanced
New bearings, gaskets etc
Hotwash
Crack tested and linished crank
The Dummy fitting began on Saturday:
Testing thrust bearing clearances:
Old bearings vs new:
Cracked crank:
Should be back in a few weeks at most :D
Who is doing it this time?
Machining was done by Blackwell race engines, and a friend of mine and an ex-supercar engine builder are putting it back together for me.
What failed on the previous motor?
The engine builder :D
It was leaking water into the oil, which was basically due to not having the head and block decked together after it was pulled apart to fix a minor oil leak. Long story short is that the engine was in and out constantly for a year, the warranty work they were doing on it was taking forever and I lost confidence in them so I cut my losses and took it to someone who I knew would have some diligence and take some pride in their work.
Those bearings were in the car for a dyno session and half a lap of Sandown...
got mine back on the track this weekend, the guys at UAS did a great job. 150+ laps flat out without any temp problems. Basically the only time we stopped was to refuel it.
next up is a 1 hour race at wakefield in 5 weeks
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
