hi guys
mark and i went to the gatton street sprints up here the week before last, and mark won outright also breaking the lap record a couple of times! set by a lola open wheeler!
i uploaded a vid tonight of one of the fast laps
also a pic i really liked, shows the spring rates could do with tweaking abit :) (thanks to redhotshotz)
cheers russ
hi guys
also a pic i really liked, shows the spring rates could do with tweaking abit :D (thanks to redhotshotz)
cheers russ
didnt you say you were going to have the 33 out there? :)
hi guys
cheers russ
Well done guys great shot.
Russ is there any chance you have a photo of the radiator with oil cooler as PWR dont have any
Thanks
Ross
Good job boys, I was a great event.
However.....
Didn't see you at Lakeside.... It was sooooooooo much fun
Great vid. I remember watching all those Grp A races and the early days of the V8s (Mezeras big one under the bridge) and thought like Amaroo Park it was gone for good. So stoked that i will get to drive it, hopefully next thhis time next year.
That said, the car looks nicely balanced and damn quick. You do a stellar job of piuloting it to, good apexes, consistant lines, and not overdriving the car like i do :blink:
ross, i thought i had a pic of the radiator , but i cant seem to find it, if i do i will post it up.
cheers russ
Cool thanks there is no rush i just want to see it and how it is set up before i go get one.
What do you think of it? Is it any good? any other major advantages?
Any info would be great thanks
Cheers
Ross
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
