Some of you know I hurt my leg last night playing sport..quite serious and cant walk.
I couldnt drive my car home but after a ring around Ash came down and drove it home for me...
Appreciate it mate. My leg is screwed...hope its better so I can go to Winton.
SAU Community FTW.
Chris.
https://www.sau.com.au/forums/topic/177355-thanks-to-the-sau-team/
