I think they look pretty good. Finally Australia is producing cars that don't simply look like blobs with too much plastic, and yes I did see the plastic around the headlights.
If I were to be given one of these cars or something with the same power from Germany, I would definitely go for the German product however if I was buying it I would most likely be paying 2 to 3 times as much.
Pretty good value for money I say.
Looks good, I like it.. Always liked the now older style F6. The enw tornado would be awesome.. factory 300KW ute with turbo goodness! Someone mentioend power to wieght, that GTP would have a hell of a lot of torque on it. never driven an aussie muscle car but u'd expect if they r selling them overseas, america and the UK, where 'real' muscle cars r really built then they must be pretty decent. Actuall sucks to hear about the commodore GTS-R.. Taken a great name code from the HR31 and made it into a f**kin banana! Would be interesting to see the new one tho and read about it. U know its going to be a good car. maybe the current F6's will come down in price from over 50k second hand.
Liam
Throw some boost into the typhoon. :)
Apparently i heard those XR6Turbos are only running on 4 psi! And they have a Garrett GT30 turbo or something like that? Not quite sure on that but i reckon if they run them on 14psi boost, lightly modded GTSTs will not be a match for them. :P
You sure heard some wild rumours. Also Lightly modded GTST's are already being thrashed off the line by lightly modded XR6T's. Driven a liughtly modded F6 and loved it. Still nothing compared to my GTR :)
Just a quick note on the subheading of this thread...
HSV finally has some competition from the Blue Oval
The turbo six-pots have had it all over the GTS, R8 etc for a very long time, champ.
Apparently i heard those XR6Turbos are only running on 4 psi! And they have a Garrett GT30 turbo or something like that? Not quite sure on that but i reckon if they run them on 14psi boost, lightly modded GTSTs will not be a match for them. :laugh:
man even lightly modded gtst's wont have shit on a stocko F6... until you start changing turbos of course
the xr6t currently run 6psi. the new f6 are going to be running about 11psi. the current f6 run about 9.5psi.
my brother in law has a ba xr6t. his made 248hp (185kw) at the wheels (100% stock). he has put a flash tune in (just an of the shelf one, not tuned specifically for his car.... yet) and pumped it up to 12psi and got 299.3hp (223kw). that is with standard exhaust, standard airbox and filter, and standard intercooler. he going to get a new airbox, intercooler and injectors and get the tune done for his car.
also the sound of the big six hitting the traction control is awesome.
a mate of mine has a xr6t. he has spent a fair bit of money on it (it developed an electrical problem when number 1 piston came out and destroyed the alternator). he had a full forge rebuild, c4 gearbox, and now he needs the diff done. on a light tune on the stock turbo at 18psi he made about 410hp (305kw).
as for the hsv gts-r i didn't think holden had decided if it was actually going to make it yet. and it takes them 7.0L to get 365kw. they have to use big cubes to get the power. atleast ford is getting 320kw out of only a 5.4L
too big, too heavy, and they use too much fuel...
i wouldnt buy one when i know that a japanese turbo car can out handle, out brake, and out accelerate for less money
unless you are talking a gtr or a fairly modded gtst they won't out accelerate a turbo xr. if you honestly think that you need to spend more time at the drag strip.
and as for handling, have you driven one? if not, then what are you basing it off? or have you driven an early e series falcon and are basing it off that? i know round where i live, where the roads are crap and rough, they would out handle a skyline cause they soak up the bumps beter.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
