yeh, those mount definately will not work, they are different heights. look like R32 GTR mounts. yours are the same as z32 300zx, same family, whales and boats. ha ha. We will get some new standard ones ordered 2moro, and get this external oil pump bracket sorted, then you can continue to bolt all your toys on.
You should know whether they will work by looking at them. You were the last one to see them alive, Stu. :D
  • Replies 843
Posted Images
Spent a day in the workshop at Bezerkly today finishing up the oil pump mounting bracket (which had to be modified to accommodate the power steering bracket and pump) and fitting up the intake and exhaust side of the motor. I've posted some pics so you can see what we started with and how it ended up.
This is what we started with this morning. The bracket had been made for the oil pump but it used the power steering pump holes instead of those once taken up by the air con pump.
This photo shows the new location for the bracket and the holes (above) that it once occupied.
The view from the front of the motor.
This is the modified bracket with the new 'L' section connecting it to the block at the top of the bracket.
This shows the pump mounted to the new bracket and the belt running to it.
The long motor with the pump mounted to the newly modified bracket.
Then things got a little more interesting. We started unpacking boxes of goodies that the car fairy had deposited at Bezerkly earlier on in the week. These goodies included the intake and exhaust sides of the motor.
Tomorrow morning the car is leaving my shed and heading into the workshop on a tilt-tray to emerge soon as a running concern.
Starting to get really exciting now!
you look to have explained it very well, besides everyone can see how good my work is. besides this thread is more interesting than mine at the moment. lots of bling to be seen. at least you know you can always enter the car in autosalon if it is to slow. ha ha ricer...
Shouldn't you be posting in here?
Edited by BezerkR32
You shouldn't post after more than one beer. New rule. :thumbsup:
soon is the emphasized word, unfortunately adrian is learning the hard way as we all do that when you modify, you can expect teathing problems. When you modify to the extent that adrian has, the more problems to rectify. some due to poor workmanship of parts supplied, others down to poor or miss-communication, and somethings you just cant forsee, oh the joys.
After repositioning the external oil pump bracket, which was much less painless than expected, we continued the fit-up. next was the plenum. Looks pretty enough but was quite envolved in fitting. It was found that the studs supplied bottomed out before they were flush with the base, which meant the gasket had no crush and would not seal. had to remove all studs, countersink holes in plenum, clean threads then re-install studs.
Plenum was now fitted. all was good until it was found that the vacuum port thread for the brake booster was welded over. had to mask plenum up, die-grind weld back, re-tap thread and machine fitting down.
Just when we thought it was all good we found that the throttle cable bracket did not have enough clearance for the cable retaining bolts. So out came the die grinder again. This was a mission for us in a workshop with all the tools necessary. Hate to have been attempting this at home in the garage.
Next was the turbo water feed plumbing. The factory pickup point was unfortunately overlooked when the block was grouted so had to find an alternative point. ended up using the port behind the thermostat housing and eliminating the bleeder port and throttle body plumbing.
next was the oil pump/sump plumbing. Just before fitting the engine it was noticed that the position of the sump pickup fitting was in a position where it would not clear the engine crossmember. Could have been worse i guess, could have fitted the engine and then noticed. The sump will have to come back off and the fitting moved.
Hopefully after all these issues are rectified it will be smooth sailing for Adrian and his project. But lessons have been learned all round. sometimes too many cooks spoil the broth, but it will all be well worth it in the end. The worst part is these setbacks which require rectifying are time consuming and therefore expensive to resolve. An unwelcome additional cost seeing you have already payed good money for the item or service provided. This is not even a case of you get what you pay for as sometimes you pay good money and it still the product or service falls short due to poor communication or workmanship.
At the end of the day communication is the key, when you are getting something fabricated or supplied, get some advise from whoever is fitting it as they may have encounted issues with products previously and can help to avoid these issues. but on some occasions you just have to suck it and see.
After the sump is modified the engine will be fitted and it should be smooth sailing.
Adrian would have much loved to race his new baby this weekend but as you can see its not going to happen. He will be racing however in a borrowed car, wish him luck for the meeting and his project.
cars getting close to running soon now then :)
Good luck with her - be great to see how you get on :D
Everytime i enter the part number into a website that sells these mounts,it keeps coming up as RB25DET NO HICAS.They must be able to fit both 2rismo's and my car?
If more people knew the grief involved before they started there would by way less modified cars out there. Its been almost 12 months of modifing the modifications, hacking, cutting changing, discarding, reaarranging components to get it all to work as a unit. I thought I did my homework but there are so many hidden perils just waiting to bite you on the arse.
The next person that tries to sell me a part and insists it simply "bolts straight on" will have said part rammed up their coit.
THERE IS NO SUCH THING AS A BOLT ON MOD?
Good luck with this build 2rismo and i hope your pain is way less than mine has been. There are quite a few up here keen to see your car run at jambo.
seriously, yor quite welcome to come to the shop and have a go, but they are the same mount that came out of my 32gtst, 33 mounts are round. they will not fit without modification and even then, what makes them any better than the standard mount that lasted 12 years before failing.
good post stuart - people incorrectly expect these things to just bolt up and off you go. as you said it is hard enough in a workshop let alone the garage at home.
one poorly made set of gtr dumps we had were on and off 4 times for modification - before we finally found out that they were not going to clear the gearbox bellhousing. bad words were said that day.
Too bad about the Plazmaman plenum Stuart, I made a thicker gasket for my plenum (I think it mentioned that in the instructions that came with it?)
Looks like the build is going on very nicely though.
Keep up the good work and look fwd to see how it goes on the black stuff. :D
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
